Gas comming out of header - JeepForum.com
post #1 of 3 Old 08-20-2009, 10:30 PM Thread Starter
Ra8erFan
I've got a weber 38/38 and my jeep sometimes has problems starting in the AM. If I tap the gas more then one time during start up then gas spills out of the bottom of my headers during high idle. Then this morning after I drove 30 miles to work gas started pouring out after I had parked my jeep and turned it off. Anyone know what could cause this?
Ra8erFan is offline
post #2 of 3 Old 08-20-2009, 10:38 PM
buckshot500
Carb needs a new inlet valve seat seal. (this is what closes & shuts off the fuel feed to the float bowl, when the float reaches it's up position)
This condition may not be so great for your engine. If raw fuel pours into the cylinders, it will wash the protective oil coating from the cylinder walls.
This will cause premature ring wear & oil dilution. Gasoline is a solvent of oil.
Originally Posted by 5point1 View Post
Well after I drained the oil, I ran water through the engine to clean out the gunk. (the guy who owned before me obvioulsy didn't know how to maintain the engine).
90YJ98XJ
buckshot500 is offline
post #3 of 3 Old 08-20-2009, 10:43 PM Thread Starter
Ra8erFan
Thanks. If I get a rebuild kit, this valve seal will be with it?
Ra8erFan is offline
abs / esp lights comming on? Intrepid4576 JK Wrangler Technical Forum 9 06-29-2009 05:36 PM
Besttop Drilless windshield header not comming off!!! Willys '05 TJ Wrangler Technical Forum 8 04-06-2009 07:55 AM
When is the Hemi Renegade comming? mr.grumpy JK Wrangler Technical Forum 17 01-16-2007 11:13 AM
Hemi comming soon? Kris B Krunch JK Wrangler Technical Forum 8 10-08-2006 10:57 AM
Lift kit comming Dans1tj TJ Wrangler Technical Forum 5 03-10-2006 09:24 AM
