Garage monkies: best way to move around axle - JeepForum.com
post #1 of 23 Old 11-13-2013, 12:13 PM Thread Starter
The_Goob
Hell on Wheels
The_Goob's Avatar
Alert
I have a dana 30 outside my garage, in the grass. need to get it in garage. heavy as crap, only have 1 wheel I can put on it. even then the steering goes all crazy when i try and lift on 1 side and push. almost pinched a finger off lol
Since I have no friends or anyone to help, whats the trick of the trade for lugging axles around?
I do have a homemade hardtop cart but it wont roll in the grass and gravel driveway
YJoTM ~April '14 ~June '15 ~April '17
The_Goob is online now
post #2 of 23 Old 11-13-2013, 12:24 PM
Norcal_chris
Norcal_chris's Avatar
I just pick them up. D30s are like little toothpicks. Ubless your an old timer then you may need a doctor visit.
Ruined a perfectly good jeep.
OCT '13 & OCT '14 YJOTM 2014 YJOTY
Norcal_chris is offline
post #3 of 23 Old 11-13-2013, 12:25 PM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
Originally Posted by The_Goob View Post
Alert
Sufficient quantities of beer should produce 'friends'....
Jack up your Jeep and steal a tire and wheel off of it for a few minutes.
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #4 of 23 Old 11-13-2013, 12:29 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Put your man hands on.
Get a piece of plywood and attach a couple fixed casters and a couple steering casters to it. Make sure you get the big ones with good tires. Drill two holes for a rope and voila: a handy cart.
Luck Favours The Prepared
Anticanman is offline
post #5 of 23 Old 11-13-2013, 12:40 PM Thread Starter
The_Goob
Hell on Wheels
The_Goob's Avatar
guess im just a girly man then cause I cant even dream of picking that thing up, just 1 side about killed me :O i managed to move it about 10 feet and gave up. the real issue is theres a hill involved
Think im going to use my cart (which has the caster setup you speak of, 3 inch wheels) and hook my recovery strap up to it and hope for the best.
Nobody wants to make that drive unless I throw in strippers and a keg, mere cans wont suffice :O
post #6 of 23 Old 11-13-2013, 12:44 PM
EABiker
Take that same piece of plywood, drill 2 holes in it, and loop some rope or a strap through them. Work that axle onto that plywood, then drag it across the grass into the garage. No lifting required.
EABiker is offline
post #7 of 23 Old 11-13-2013, 12:46 PM
HAYSHAKER170
front end loader
HAYSHAKER170 is offline
post #8 of 23 Old 11-13-2013, 01:04 PM
rap169
Simple hand truck which a ratchet strap
rap169 is offline
post #9 of 23 Old 11-13-2013, 01:06 PM
Old4X
1990 CJ7
Hay forks on a 3 point hitch.
Boom pole and chain on a 3 point hitch.
Chain to an all purpose plow and move with.......the 3 point hitch.
See any similarities here?
Old4X is offline
post #10 of 23 Old 11-13-2013, 01:11 PM
rebelbowtie
It's only a D30, me and a friend carried a 14bFF and fully dressed D60 out of his pick up truck and into his back yard just the other night.
rebelbowtie is offline
post #11 of 23 Old 11-13-2013, 01:25 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I'm gonna guess a tractor...
post #12 of 23 Old 11-13-2013, 01:27 PM
HaskiE
HaskiE's Avatar
2x
edit: it's called a movers dolly, and they're $12 at harbor freight
http://www.harborfreight.com/movers-dolly-93888.html
#theneverendingaxe
HaskiE is offline
post #13 of 23 Old 11-13-2013, 01:32 PM
Shadownwpa
Shadownwpa is offline
post #14 of 23 Old 11-13-2013, 01:44 PM
jason280
I've always found that a Kubota L4330 with a FEL works wonders for moving axles....especially PITA front axles. Other than that, you can try bolting on a set of tires/rims to roll the axles around. As far as moving around in the garage, I fab'd up a 3/16" piece of plate on a 3 ton jack to hold axle assemblies, and it makes moving a lot easier.
None
jason280 is offline
post #15 of 23 Old 11-13-2013, 01:59 PM Thread Starter
The_Goob
Hell on Wheels
The_Goob's Avatar
Wow I didnt expect all this response. I ended up using strap and hardtop cart, and of course my 2yo daughter did all the pulling since I'm such a weenie :P
the 15 degree weather hardened up the ground that helped
I think its going to stay there for awhile too seems better than using up 2 of my 4 jackstands till swap.
