gap with hard doors on - JeepForum.com
post #1 of 6 Old 07-20-2004, 07:19 PM Thread Starter
jeeper1221
i bought a hardtop and doors for 300 bucks and i tried to put the passenger door on with my soft top and there is about a 1 inch gap between the door and the windshield frame. is there some kind of seal i need?
jeeper1221 is offline
post #2 of 6 Old 07-20-2004, 07:24 PM
wm69
Loosen the hinge bolts on the door hinges and it should move around where you can adjust it, then tighten the bolts back up. Be careful as they are the $%^# torx bolts and they strip easily.
wm69 is offline
post #3 of 6 Old 07-20-2004, 07:30 PM
RCHavok797
RCHavok797's Avatar
There are soft tops made to fit the full hard doors and soft tops made to fit the half doors. It seems you have a soft top that is made to fit the half doors so adjusting the doors like mentioned above is pointless.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #4 of 6 Old 07-20-2004, 08:49 PM Thread Starter
jeeper1221
ill try to adjust the hinge, but the gaps on both sides of the door look the same. only between the top of the door frame and the windshield frame have a gap, i can fit my fingers through it . and to the above post even if i put on the hard top there will still be a gap.
post #5 of 6 Old 07-21-2004, 06:40 AM
wm69
You can also (at least on CJ's) adjust the angle of the windshield frame by loosening the bolts holding the bracket onto the bottom of the windshield (where there is a knob on CJ's for lowering the windshield. I'd do this AND the hinges on the door and you should be able to come up with somthing acceptable (you will probably have to move your striker pin if you move the door around on the hinges much).
wm69 is offline
post #6 of 6 Old 07-21-2004, 09:04 AM
BeatAChevy289
BeatAChevy289's Avatar
Doubt the windsheild thing would work. I think all YJ's have sportbars so you'd have to take them off to get any windsheild movement. It's that the soft top wasn't made for the full doors. Stuff usually tends to line up pretty well on YJ's. Later <><
1995 Firebird Formula, 6-speed, LT1 V8, t-tops, open exhaust. **In the For Sale section***
1966 Ford Mustang, Hi-Po 289 V8, 4:11's, I dare you to race me.
(different from the other link)
BeatAChevy289 is offline
hard topw fulls doors vs soft top w half doors airdevil85 YJ Wrangler Technical Forum 5 01-13-2010 10:37 AM
Hard Top - Hard Doors Improvised Rattle solving thread bparsel YJ Wrangler Technical Forum 7 07-22-2009 07:23 PM
Half Hard Doors vs Full Hard....Key Cylinders Swappable? Hunta TJ Wrangler Technical Forum 17 05-13-2009 02:57 PM
Soft top? full hard doors vs. half doors jgarden TJ Wrangler Technical Forum 8 10-17-2004 02:00 PM
Buying TJ with hardtop & hard doors, but I want a soft top & half doors xxxxxxxxxxxxxxxxxxxgksspot TJ Wrangler Technical Forum 11 10-26-2003 09:16 AM
