11-07-2007, 04:12 PM
#1
Gap between door and windshield
I went to put the full doors on last weekend only to find there is a gap between the door and windshield frame at the top (like a V shape). Is this just a case that the hinges need to be adjusted? I would have messed with it more, but I was doing this while I was home sick, and didn't have the energy to mess with it.
11-07-2007, 04:16 PM
#2
Some pictures would sure help.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
11-07-2007, 04:23 PM
#3
Unfortunatly, I don't have a digital camera anymore, had to give it back when I quit my last job.
It seems like the door is sitting correctly at the lower portion of the window, but then as it goes towards the top of the frame the angle widens to probably close to 3/4". I'm a little surprised, they're off a CJ, so they should fit correctly.
11-07-2007, 04:44 PM
#4
I know what you mean, I had the same problem. Turns out the roll bars over the door (from the hoop to the windshield) had slipped a bit and got longer. So I took the lower plates off the windshield and loosened the bolts on the bars. I closed the doors and while standing on the seat, pulled the windshield back, till it was flush with the doors. Then tightened the bolts and replace the windshield plates. Problem solved.
1990 YJ, Colorado Red with 'Laredo' markings, 4.2L, TF999, NP231, Valvoline Syn fluids, Weber 32/36, Nutter Bypass, Dana 30/35, 16" Electric Fan, Optima Yellow Top, 140amp alt., K&N Air Filter, Cherry Bomb muffler, SRC Front Bumper, CH&F Shackles, KC 100w Daylighters, Homemade Lightbar, Rear Aux lights, Cobra CB/PA/WX, 102" Whip Ant., 400 watt power inverter, 2 fire extinguishers, Mobile Internet & WiFi equipped.
Daily Driver since April 23rd, 2003
Northern Illinois Extreme Jeep Club Member www.extremejeepclub.com
Weber 32/36 Install -> http://www.jeepforum.com/forum/f12/weber-32-36-install-write-up-382309/
Early YJ Club Member # 37
For anyone with a 4.2L --> http://groups.jeepforum.com/258s_Unite
11-07-2007, 05:02 PM
#5
the bolts to the windshield frame? or are there bolts at the hoop?
91 Sahara 4.0l Operation Welcome Home Parade Veh #69
PARADE JEEP MEMBER #1Auto posi-lok equipped, 4" susp. lift
K&N Drop in and loaded with battle scars
www.americaisfull.com
FOR SALE 2005 PT CRUISER CONVERTIBLE
2005 Suzuki DRZ400S For SALE
11-07-2007, 05:07 PM
#6
XJ on 37's
You have doors?  actual full metal doors? wow!
show off.....and hell, you want them to have no gaps too? greedy.....
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee....
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover 4.6 HSE
2000 4.7 4WD WJ with a rebuilt motor.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
Years to gain the hands on experience, and offer it freely.
Minutes to gain the knowledge from the internet, and quote it just as freely.
Choose wisely!
11-07-2007, 05:10 PM
#7
I actually just got doors and a top too, yeah it would be nice if there weren't any gaps around the doors, but do the bars that connect the hoop to the windshield have any sort of bolts at the hoop side????? I can't tell because of sound bar
11-07-2007, 05:14 PM
#8
the bars are in two pieces, a long shaft that attaches to the windshield that slides over a stub bolted to the hoop. There is a torx bolt on top of the bar on the hoop side, that is what you would need to loosen to adjust the length.
Weber 32/36 Install -> http://www.jeepforum.com/forum/showthread.php?t=382309
11-07-2007, 05:15 PM
#9
Thank you sir!!!!!!!!!!!!
11-07-2007, 05:18 PM
#10
same problem, the bolts in the roll bar above your head, like ^^^ he said, however he did leave out that they are those wonderful TORX I beleive a 50, or 45, and they are the non stealable kind with the knob in the middle so you will have to go buy a new set of torx for them, LOL..... GOD DAMN THINGS, I took those out and replaced them with regulare bolts....oh and you have to take the top off to get the Torx out....LOL,
dont you love jeeps
11-07-2007, 05:20 PM
#11
I just took a dremel tool and carved out that knob
11-08-2007, 07:33 AM
#12
Or you can get a good set of vise grips, remove the torx, and then use a hex bolt. Worked for me. Saves the tropuble of buying more torx bits. That is of course after an hour of cursing. Oh the joys of Torx.
Herculined, MC2100, Nuttered, 31" Mud Rovers
11-08-2007, 10:42 AM
#13
Great, thanks for the advice, I'm going to check it out when I get home from work tonight!
11-08-2007, 11:02 AM
#14
Vise grips LOL I had to use an electric impact on mine to get them to move.....and even then the bolt I think is longer tehn the gap between the bar and the top....
11-08-2007, 05:26 PM
#15
I have a opposite problem . My doors are WAY tight. Almost cant get the doors shut. I think I must have pushed the windshield back a bit. Damm trees.
