gaer question - JeepForum.com
post #1 of 2 Old 02-06-2002, 10:10 AM Thread Starter
MY95
MY95's Avatar
gaer question
i have a 95 4banger w/ stock gears and running 32x11.50 i have read about replacing the gears w/ 4.88 how would this improve my performance and what about cost
95 YJ 2.5L w/3.5" Superlift, 1" BL
33x13.50 Swamper LTB on 15x8 Eagle 589s
Mile Marker E12000, Optima Yellow Top
MORE 5/8" Boomerang shackles, Hi-Lift Jack
4.0 TB w/ poweraid spacer, Rustys air tube, K&N filter
WHITE Jeep club member # 007
MY95 is offline
post #2 of 2 Old 02-06-2002, 10:35 AM
YJ Dude
Do you do a lot of rock crawling? If not, I would not spend the cash on 4:88. Regearing is expensive. If you on not have a press and a lot of time and patience, I wouldn't recommend attempting it yourself. I have the same setup as you and am running 33's on the rocks without too much problem. It just depends if you have that spare 1K laying around that you don't know what to do with. Swapping out axles with stronger ones from say a Wagoneer is more economical if you are still wanting lower gears.
94 YJ, 2.5, 4" ProComp Lift, 33's,
EZ Locker, Warn M8000 winch, Home made tire/jack carrier, nurf bars.
YJ Dude is offline
Lift/Tires question and Cleaning soft top & engine question Bryan_16 TJ Wrangler Technical Forum 16 05-19-2012 03:25 PM
Front sway bar question + bonus disco question WranglerTom TJ Wrangler Technical Forum 7 12-02-2011 08:13 AM
1988 carberator question and wiring (general) question prljeep YJ Wrangler Technical Forum 15 05-08-2009 11:50 AM
quick connecting rod question and tourqe wrench question???? johnrezz YJ Wrangler Technical Forum 2 10-18-2008 07:20 PM
Tire question(noob question but just a quick answer needed) 07SilverX JK Wrangler Technical Forum 3 12-25-2007 03:35 PM
