FYI...If your looking for a York compressor..... - JeepForum.com
post #1 of 1 Old 03-29-2002, 09:59 PM Thread Starter
Missin44
For those like me that are planning on or installing OBA using a York compressor, I have some info that might help in your search. There are 3 models, the 206, 209, 210. The 210 being the one most want. Problem is where to find the 210's. You can look at the tag or shaft. If its still in the vehical and the clutch is still attached, the shaft ID is not possible. But what cars carry the 210's vs. 209 or 206? Now its easy, I think. Find a early 80's Volvo. I found 5 today - 2 DL's(82,83); 2 CL's(84's) and a 244DL(82?) - all had the 210's. The tags are hard to read because the compressors are installed in the bottom of engine bay. Anyway the point is 5 Volvo's of early 80's and 5 210's. I may be onto something!
Good Luck
'92 YJ, 4.0L, 5 spd, OX Locked front, 4:10 gears, BDS 3.5" lift, reverse shackles, Ford 8.8 Limited-slip rear, York OBA, JB Conversions SYE Kit, CV driveshft, Centerforce II clutch, Big Daddy Step Rock Rails, Skid Row Top Prop, Big Daddy OffRoad Front Bumper, Yokahoma Geolander 32's, Rokmen Riddler differential cover
Missin44 is offline
York Compressor for OBA, which? DaleII TJ Wrangler Technical Forum 12 12-22-2009 01:46 AM
York A/C Compressor Jeepman321 TJ Wrangler Technical Forum 2 09-14-2009 01:14 AM
York vs A/C Compressor themattreid TJ Wrangler Technical Forum 6 07-10-2007 04:41 PM
York Compressor bryan-2kevo YJ Wrangler Technical Forum 1 09-22-2006 05:38 PM
Sanden Compressor Clutch work on a York Compressor? Stricken TJ Wrangler Technical Forum 2 07-15-2004 12:55 AM
