Fusible Link - JeepForum.com
post #1 of 2 Old 06-05-2011, 02:53 PM Thread Starter
fatladyvalkyrie
Fusible Link
Jeep shut off while coasting into the driveway the other day. No action when I turned the key. I crossed the starter and it cranked so I pulled the battery and mount to get a good look at the starter relay. The fusible link is melted through. Should I be looking somewhere for a short? I would assume so but I don't know where to start. I did trace some wires and see that the PO did some re-wiring. The wires going to/from the ignition switch are spliced together (just barely making contact).
Any suggestions on where to go first?
'89 YJ 4.2L
I'm not a vigilante --- I'm an undocumented border patrolman
fatladyvalkyrie is offline
post #2 of 2 Old 06-05-2011, 03:05 PM Thread Starter
fatladyvalkyrie
Forgot to add another question, I don't see it on the wiring diagram that I have, but the fusible link is two wires going to one ring terminal vs. just one wire, where is the other wire coming from?
Ignition fusible link yjweber YJ Wrangler Technical Forum 2 04-14-2011 03:52 PM
fusible link bubblefishpro YJ Wrangler Technical Forum 5 08-28-2010 02:30 PM
YJ Not charging??? Fusible Link??? SignGuy321 YJ Wrangler Technical Forum 6 09-24-2009 11:28 AM
Fusible Link help Ratmeat YJ Wrangler Technical Forum 5 01-03-2009 06:33 PM
Fusible Link? Dougs321 YJ Wrangler Technical Forum 0 01-03-2008 06:44 PM
