Fuse Block Help - JeepForum.com
post #1 of 3 Old 12-17-2011, 12:14 PM Thread Starter
EZ95YJ
Fuse Block Help
I've been having some trouble with the blower motor fuse burning. So I turned to old faithful and read some threads on the topic. I figured out how to get the fuse block out and sure enough the one connection on the blower fuse is burnt. Here is my issue...there is a green wire going to one side of the fuse...here comes the confusion. The other side has two brown and orange wires coming in. One comes in from the wire harness and the other jumps to the rear wiper. Could that be jumping power to the rear wiper? Sorry, but I'm not an electrical Guru and I don't want to do this again. Can anyone give some advise on this? Thanks!
EZ95YJ is offline
post #2 of 3 Old 12-17-2011, 03:26 PM Thread Starter
EZ95YJ
Where are the electrcal wizards? Anybody...a little help?
EZ95YJ is offline
post #3 of 3 Old 12-17-2011, 04:46 PM
timatoe
timatoe's Avatar
Mine wasn't like that, it had power in and then out, I bypassed the block all together and put an inline blade fuse in. I suppose it's possible that the wiper draws power from there, I'd just hook it into the new block that the old one was.
timatoe is offline
Fuse box/block ????? j33p4l1fe4x4 TJ Wrangler Technical Forum 3 12-28-2010 08:08 AM
97 TJ fuse block stuff2c TJ Wrangler Technical Forum 3 12-28-2010 05:50 AM
Adding and AUX Fuse block and Relay Block letitloose06 YJ Wrangler Technical Forum 2 07-23-2010 07:38 AM
Aux. Fuse Block Dewster196 YJ Wrangler Technical Forum 0 08-11-2009 06:10 PM
Fuse Block RedLion YJ Wrangler Technical Forum 3 11-15-2007 09:47 AM
