Fuse #9 Keeps Blowing - JeepForum.com
post #1 of 19 Old 02-24-2013, 03:42 PM Thread Starter
cstone94
The #9 fuse, which is a 15 AMP fuse that powers the gauges and info lights on the dash keeps blowing. I've gone through 3 in 10 minutes. What would cause this?
95' YJ - Warn Bumpers/Tire Carrier/Winch - 2.5L - 6" Skyjacker Suspension Lift - 4.10's - Locrite Locker - Dana 35/30 - 35" BFGoodrich KM2's
11' F250 - DD
1982 Toyota Pick-Up - Spray-On Yellow Rhino Lined - Chevrolet 305 H.O. - SM465 - NP208C - All-Pro Off Road 5" Springs - 35x15.50x15 Super Swampers
cstone94 is offline
post #2 of 19 Old 02-24-2013, 04:55 PM
pete1991YJ
A direct short somewhere in the gauge harness.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #3 of 19 Old 02-24-2013, 07:19 PM Thread Starter
cstone94
Do I need to remove the dash to get a view of all this? Should I go ahead and clean up all the contacts for the gauges while I fix this problem? Anything else I should do while the dash is out?
11' F250 - DD
cstone94 is offline
post #4 of 19 Old 02-24-2013, 07:28 PM
pete1991YJ
I would at least pull the center 4 gauges and the trim around the speedo and tach. Then pull the radio and ashtray. It makes it *much* easier to poke around in there, and it isn't hard to do. Philips head screwdriver is all you need. Helps to magnetize it so the screws don't fall off and disappear. Might as well get the contacts while you're at it.
post #5 of 19 Old 02-24-2013, 09:00 PM Thread Starter
cstone94
Okay, I won't have any time to work on it this week. I'll tear into it the first of next month when I'm off for spring break.
11' F250 - DD
cstone94 is offline
post #6 of 19 Old 02-24-2013, 09:20 PM
Old4X
1990 CJ7
You can have the whole gauge cluster in your lap in under 5 minutes, not difficult at all.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #7 of 19 Old 02-25-2013, 10:03 AM
Que89YJ
You are dealing with an intermittant short. That fuse suplies Defogger relay and switch, guage pack, tach, buzzer module, indicator lamps and the mainteance timer. The best way to troubleshoot it is the old shake method. The old light bulb method is the best way. Look at this video. I usually just use a light bulb and socket myself. The bulb itself will act as a fuse if the current draw gets too high. I use the intensity of the bulb to tell if the current draw goes up(short). Start by checking the cluster. Corrosion is very common on the circuit board.
http://www.jeepforum.com/forum/f12/r...er-how-991307/
Here is a search for that fuse blowing.
http://www.google.com/webhp?hl=en&ta...w=1688&bih=759
Que89YJ is online now
post #8 of 19 Old 02-25-2013, 10:08 AM
90DesertTanYJ
As indicated this fuse covers quite a few components. You can try and unplug them all to check just the wiring then plug one back in at a time. The gauge cluster has a flimsy copper pathway piece that supplies power and grounds to all of the gauges. It is very prone to problems in our 25 year old vehicles. Unplug the whole gauge pack and see if its the problem. You can get an aftermarket supposedly improved pathway for about $80 off eBay. You can also hard wire the gauges to eliminate the problems forever.
Good Luck!
90DesertTanYJ is offline
post #9 of 19 Old 02-25-2013, 10:33 AM Thread Starter
cstone94
Thanks for all the information! So when I pull the dash, should I look for a bad ground first? It seems like hitting a bump causes the short. I'm pretty new to electrical so bare with me!
11' F250 - DD
cstone94 is offline
post #10 of 19 Old 02-25-2013, 10:45 AM
pete1991YJ
Its not so much a bad ground, as it is a ground where you don't want it to be grounded.
If it seems like hitting a bump causes it, then that is a good time for the "shake test". Turn it all on while you have the dash out. Reach in and start grabbing wire harness. Try to shake or move it around. Pay special sttention to where the harness is near sheetmetal or moving parts such as pedals or steering column.
While shaking or moving it around, its bound to blow it again. Whatever is in that particular part of the harness is part of the prob.
post #11 of 19 Old 02-25-2013, 10:48 AM
Que89YJ
Turn on your tail lamps and check it with the shake test. If I remember right that one goes to the tail lights and the wiring shorts on the lamps is pretty common.
post #12 of 19 Old 02-25-2013, 10:48 AM Thread Starter
cstone94
Okay thank you. Like I said, I won't have time to fiddle with it all this week since I'm at school. Spring break starts this weekend so I'll check it then.
11' F250 - DD
cstone94 is offline
post #13 of 19 Old 02-25-2013, 12:05 PM
Siva283
Also check the Reostat and headlight switch. Mine was doing the same thing a year ago. It was a bad Reostat.(The dimmer wheel for your gauge lights). If I left it off it was fine. If I turned it on it blew the fuse. Changed it and the headlight switch since I had been have issues with it over heating and shutting my lights off. I have had no probs since. So you might want to check it as well.
Ask me how I know...
Siva283 is offline
post #14 of 19 Old 03-09-2013, 11:01 AM Thread Starter
cstone94
Here goes nothin
11' F250 - DD
cstone94 is offline
post #15 of 19 Old 03-09-2013, 11:11 AM Thread Starter
cstone94
I have no idea what I.should.be lookin for
11' F250 - DD
cstone94 is offline
