Funny Sounds??? - JeepForum.com
post #1 of 3 Old 12-30-2001, 06:57 PM Thread Starter
grantnps
Funny Sounds???
The other day, a loud rattling sound started and its sounds like it is coming from the left part of the car...maybe near the firewall. Then today.. it stopped and a softer sound started near the same place. This second sound is hard to explain, but it is repetative about every half a second, kind of high pitched. Im thinking that it is because of the cold whether recently... it has been around 50 degrees, and all of the sudden its snowing here.
Has this happened to anybody else...if so, any suggestions are great..thanks,
Grant
'94 YJ 4 banger :( 4" ProComp suspension 32x12.5 a/t's, flow's, kn air filter charger, and lots of little appearance mods.
grantnps is offline
post #2 of 3 Old 12-30-2001, 07:20 PM Thread Starter
grantnps
I was just reading another topic, and my therm. doesn't work either. It always stays at cold..and never moves...could the water thing be the problem? I don't know.
grantnps is offline
post #3 of 3 Old 12-30-2001, 08:31 PM
glm 87 wrangler
As for the rattle dont have a clue.But as for the thermostat you may have a problem with the sender.If you are getting no reading its most likly the sender.but if you are getting a low reading it may be your thermo.But the only noise if the thermo was stuck close would be the sound of your jeep over heating and you would see and know that right off hand.the sender is located by the intake manifold.it will have a wire running to it.hope some of this helps.Later,Gary
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
New Guy Here! 93 yj odd sounds tholliday YJ Wrangler Technical Forum 7 09-17-2009 11:09 AM
Some sounds GIJoe Driver JK Wrangler Technical Forum 3 05-27-2007 06:06 AM
sounds like a rip off to me mkalcevic TJ Wrangler Technical Forum 12 06-13-2006 02:07 PM
jeep sounds funny jeep jake TJ Wrangler Technical Forum 3 01-16-2006 11:50 PM
Tell me how it sounds... vanilla_gorilla TJ Wrangler Technical Forum 13 02-24-2004 12:15 PM
