Full width outboard rear shocks question - JeepForum.com
post #1 of 9 Old 09-26-2013, 08:14 AM Thread Starter
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Im still collecting parts, but Im about 99% sure I will be running the H2 wheels with 37x12.50 tire. My question is with using the H2 wheel will I still have enough room to outboard the rear shocks? I was going to purchase the Ford shock towers. If possible I would rather not french the frame. Thanks!
Edit: Minimal frenching if possible
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
post #2 of 9 Old 09-26-2013, 09:48 AM
GrantYJ
Do you mean H1 wheels (military double beadlocks)?
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
post #3 of 9 Old 09-26-2013, 11:09 AM
'92 vegas YJ
Pretty sure he means H2s. They have pretty decent backspacing
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is offline
post #4 of 9 Old 09-26-2013, 11:51 AM Thread Starter
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
I do mean H2 wheels. Vegas you were correct I want the H2 wheels so the jeep doesnt look like a 1970's roller skate. I just dont know what that backspacing will leave me with as far as out boarding the shocks. I was hoping to find someone running the H2's and outboarded shocks. I have seen quite a few rigs through the years that are running h2 wheels so I know that a couple of them have out boarded the shocks. Im just not a fan of reducing a 2-1/2" wide frame rail. Epecially considering the moments that will be put on it during offroading. I see some of these frenches people are doing and as a mechanical engineer I can tell you there is no way in hell their now 1" wide (or less) frame is not going to tweak in the applications they are using it for. Now maybe some gusseting or cross bracing between the frame rails could mitigate that, I just havent seen any examples of any.
March 2017 YJOTM
87TPIYJ is offline
post #5 of 9 Old 09-26-2013, 01:41 PM
'92 vegas YJ
Really it all boils down to the width of your rear axle. What rear axle are you planning on running? You're going to have to French your frame. Unless you're running a 70" wide rear axle with 2" of backspacing.
Or you can chop you're rear frame off and build a new narrower frame so you don't have to French it.
post #6 of 9 Old 09-26-2013, 02:21 PM
GrantYJ
I agree with Vegas.
I wish I could help you, but I'm completely unfamiliar with H2 wheels on anything but a hummer. With H1s, you've got some options; however, from what you've said, I don't think that you'd like them.
I understand that you want the benefits of full width axles, shocks set outboard, and a narrower track with the H2s. I also understand why you don't want to slice into a relatively thin wall frame and potentially reduce it's strength (especially with the spring hanger right behind it); however, you've got to compromise somewhere. Unless you find someone who has done this with the exact same axle and wheel, you're going to have to mock it up to find a happy medium. You can only fit so much into the space available.
GrantYJ is offline
post #7 of 9 Old 09-26-2013, 03:43 PM
rambo3489
You will have to do something. I have 35's with 3.75" BS and was about 2" short. How about this?
Honestly the best option IMO. I'm not just saying that because it is what Ive done. I have heard many times not to weld vertically across a box frame. But rather to use through bolting to secure things to a frame. If it was a coil sprung vehicle I would not have a problem cutting and frenching. But with leafs that area does take some additional stress.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #8 of 9 Old 09-26-2013, 06:44 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Exactly.
Not mentioning this puts a real damper on quality feedback.
Joe Dillard is offline
post #9 of 9 Old 09-27-2013, 03:03 AM Thread Starter
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Sorry sterling 10.25.
March 2017 YJOTM
87TPIYJ is offline
