full steel door wont open - JeepForum.com
post #1 of 19 Old 09-04-2011, 08:37 AM Thread Starter
Anonymous6915
2009 JK Wrangler
ok so i had my passanger side door out to replace the outside handle and i lubed everything up.
Thursday i decided i would start locking the doors() now the passanger side door will not open. It locks and unlocks fine but will not open.
Its still on the jeep b/c i cant get it open but i did take out the panel and take a look inside. everything looks like its working correctly but the door will just not open.
Anyone ever experiance anything like this? PLEASE HELP...TIa
Anonymous6915 is offline
post #2 of 19 Old 09-04-2011, 09:08 AM
nembudonna
I had the same thing happen to me. You can't get the cover off with the door closed to get at the parts. Check that long rod. I don't know what you call it, but that's what came loose. There is a clip on it that breaks and it won't work. But you can't get to it unless you take off that little panel. I had a friend with little hands come over and he got it on.
nembudonna is offline
post #3 of 19 Old 09-04-2011, 09:50 AM Thread Starter
Anonymous6915
2009 JK Wrangler
i got the small metal panel off but i dont see anything wrong with the rods, they work just fine(i think) i just cant get the door to release...
post #4 of 19 Old 09-04-2011, 09:55 AM
sofixj
sofixj's Avatar
same thing happened to me last week. i had to remove the striker from the tub, unbolt and fold down the windshield and lift the door off with a buddy. once on the ground we found that the door stiker latch siezed up and i have to replace it. Im going to cj5.com on tue he said he has a few and only $25.00 so now im running door less and topless till then.
,=====o00o
//___l__,\____\,___
l_--- \___l---[]lllllll[] _
_(o)_)___(o)_)--o-)_) only in a JEEP
sofixj is offline
post #5 of 19 Old 09-04-2011, 10:07 AM
nembudonna
How did you get that panel off with the door closed? There are are those 2 screws that you can't get at. When mine was stuck it would just pull but you could tell it wasn't working anything. But it would lock and unlock like your saying. The reason I think it's the rod is because you just replaced the handle.
post #6 of 19 Old 09-04-2011, 10:31 AM Thread Starter
Anonymous6915
2009 JK Wrangler
well i didnt put all the screws back so i was able to get the panel off by taking the other screws out...
post #7 of 19 Old 09-04-2011, 10:45 AM
nembudonna
Then you can see where that long rod goes. There is supposed to be a clip on it. What ever, just push or pry that piece rearward.
post #8 of 19 Old 09-04-2011, 12:32 PM Thread Starter
Anonymous6915
2009 JK Wrangler
would you mind showing me which one? i just went out there and i cant get it to release.
sorry for the large pix. i cant get them smaller...
post #9 of 19 Old 09-04-2011, 01:25 PM
lestes94
One problem could be that the rods could be out of adjustment. Where it goes into the clip, if it isn't exactly right, the rod will be shorter(or longer) and won't work correctly. Happened to me before. If you do take them off, just put them up to the clip to where it fits naturally, not pulling on it or anything, then snap it in. Might not be your problem, but it can give you the same problems.
lestes94 is offline
post #10 of 19 Old 09-04-2011, 03:45 PM Thread Starter
Anonymous6915
2009 JK Wrangler
well, its not the rods or clips, everything works identicly to the driverside door which works fine. it seems to me like the latch piece just doesnt want to let go, is this a common problem with an easy fix? i dont want to have to take my hardtop off and move my windshield and unbolt the whoole damn thing...
post #11 of 19 Old 09-04-2011, 06:03 PM
nembudonna
don't take the top off. The long rod should release the latch. If you just push down on the latches that hold the pin on the right it will open. Looks pretty rusty. Just pry those too levers toward the front.
post #12 of 19 Old 09-04-2011, 06:08 PM
Mark05059
looks like your door might be siezed on the latch part... try holding the inside handle in the open position and giving the door a good hit (kick it from the inside near the latch) and see if the door flys open.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #13 of 19 Old 09-04-2011, 06:16 PM
nembudonna
Just push the bottom latch down and the top up. Wedge them if you have too.
post #14 of 19 Old 09-04-2011, 09:40 PM Thread Starter
Anonymous6915
2009 JK Wrangler
so basicaly, force the two hook looking things apart from the strike? i was trying to but not to hard as i didnt want to break it but if you guys have done this before, ill feel better doing it.
post #15 of 19 Old 09-04-2011, 10:55 PM
JeepsOLot
My passenger side full door did that a year ago. I had to bend the plate covering the latch back, then, take an angle grinder and cut the latch itself. On mine, you could see that the springs for the latch "clamps" broke, didn't matter what the rods did, it would not open. Haven't even tried to find out where I can get a new latch yet, but, I have a set of soft doors, so, it's ok.
Jerry
86 MJ LB Custom, 88 MJ SB Eliminator, 92 CJ9, 93 XJ Country, and 04 WJ Laredo/Limited
JeepsOLot is offline
Cant open full steel doors from outside gattaca37 TJ Wrangler Technical Forum 4 12-20-2010 06:25 PM
Need to replace full steel door with light weight door LenC JK Wrangler Technical Forum 17 05-11-2010 04:18 PM
Need to replace full steel door with light weight door LenC TJ Wrangler Technical Forum 22 05-10-2010 01:17 PM
full steel door wont work esgo77 YJ Wrangler Technical Forum 0 07-02-2008 09:44 AM
YJ full steel door... anyway to seal the gap left between rollbar and door ? intenseblu YJ Wrangler Technical Forum 6 06-11-2007 08:07 PM
