Quantcast Full Steel Door Repairs - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Full Steel Door Repairs
Old 09-17-2007, 12:54 PM   #1
Cod
Junior Member
Cod's Avatar
2010 JK Wrangler
Was wondering how (not if cause I know other ppl have the same problem) some of you fixed this problem.
My YJ has full steel doors, the drivers side glass frame has came loose near the rear of the door, it's still usable it just shakes.... and whisles while riding down the road. You know the area where they all break and being to crack the door itself.
It looks like you could weld, put a screw in or something to fix this but I just have not found the best way to do it.
Any ideas suggestions??
Cod is offline   Reply With Quote
Old 09-17-2007, 01:03 PM   #2
cheap5.0
Sand it clean of everything (paint, primer, sealer, rust) and take it to a welder in town. Have him Tig it back together. I think that would be the best route, unless you know how to Tig yourself and have a welder.
Or even get alittle piece of metal (1/4-1/2" wide, 1/16" thick and have him weld that like a brace holding the two together. It would be pretty small and would not be noticeable with just a glance. It would also be stronger than it is now and would probably fix this problem permently
Carry Concealed on Campus
cheap5.0 is offline   Reply With Quote
Old 09-17-2007, 02:08 PM   #3
kloppk
I had the same problem with my YJ's drivers side door.
A couple of minutes with my mig welder and some touchup paint - done.
kloppk is offline   Reply With Quote
Glock Forum
