full steel door hinge pins? - JeepForum.com
post #1 of 12 Old 08-08-2010, 08:22 PM Thread Starter
jeeptim
I acquired a set of full steel doors but one of the doors is misssing the actual pins, the hinge is there but no pins. I can't seem to find a place that sells these seperately. any ideas? Thanks
1989 Islander 4.2 Automatic. RC 2.5" lift. 265/75/16
jeeptim is offline
post #2 of 12 Old 08-08-2010, 08:27 PM
Devilsmed98
Not sure what you mean because when I bought my jeep there were no pins. Just a steel screw with little thread on the bottom to hold a nut. They work great. And fit snugly. Not sure if this is the way its suppose to come because they look fairly new compared to the rest of the jeep, but they should come like this factory.
~Black WK Club Member #9~
2011 WKII Overland
2007 WK Limited[/COLOR]
1995 YJ Rio Grande
Devilsmed98 is offline
post #3 of 12 Old 08-08-2010, 10:47 PM
MJMPC
This is all I could find.
Door Hinges and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware-RH2
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #4 of 12 Old 08-08-2010, 11:57 PM
timbertiger20
The hinges on the door itself should have a threaded bolt end sticking down. The hinges on the body should have the hole for the studs to go though and then have a nut at the bottom. They may have switched the body and door hinge.
timbertiger20 is offline
post #5 of 12 Old 08-09-2010, 12:09 AM
Firefyter-Emt
Given the design on the hinge.. I would have to say that the pin came out of the hinge. I believe the pin is just welded in from the top of the hinge. Easy fix, buy new hinges... made hard by Jeeps satanic pact with all things having to do with torx.
If that is not going to work, I am willing to bet you can find some round stock that would fit the hinge. If it's a nice tight fit, clean it out and add some lock tight, then tap the new pin in place. Worst case, you can have a shop custom turn a piece of sock to fit the proper pin diameter to replace it. FWIW, my older CJ style doors do not have threaded ends, just tapered pins.
Firefyter-Emt is offline
post #6 of 12 Old 08-09-2010, 12:24 AM
timatoe
timatoe's Avatar
One of my half doors was like that when I bought them. It's just got a bolt through there now. I have no idea where you may be able to get just the pin part, you'll probably have to get an entire new set of hinges.
timatoe is offline
post #7 of 12 Old 08-09-2010, 07:39 AM
Area.3.Fiftyone
Get a long grade 8 bolt, cut the head off, tap it in and weld the top just like the OEM pin would be.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #8 of 12 Old 08-09-2010, 07:16 PM Thread Starter
jeeptim
one of the doors has the hinge pins and they are grooved on the end and just tap into the hinge, they are not welded, I see a couple of bolts in my future =)
jeeptim is offline
post #9 of 12 Old 08-09-2010, 08:17 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
My hinges are in tough shape also but I don't want to spend the $$$ to replace them.
It seems that IronMaiden and I must be on the same wave lenght on this fix. Grade 8 bolts tapped in and welded is the cheapest fix I figured, even if you have to hire out the welding portion of the job.
Or you could insert the grade 8 bolt, cross drill it and install a stainless steel roll pin, but welding in the bolt is the way to go.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is online now
post #10 of 12 Old 08-09-2010, 08:23 PM
johnoutdoors
3/8 rod will fit pretty well. made a mirror to fit in there so its legal with the doors off.
johnoutdoors is offline
post #11 of 12 Old 08-09-2010, 08:32 PM
Burlbook48
Trial By Trail
Burlbook48's Avatar
What's with all the welding, cross-drilling, and roll pins? Just grab a 3/8" hex bolt. Make sure it's long enough to double-nut the end so you don't have to tighten it down on the door hinge.
3/8" threaded rod fits though the hinge (I made mirrors for going doorless too), but a bolt with it's smooth shaft would work better for the hinge. Cut off the excess bolt after the double-nut on the end.
You have to start somewhere to get to the middle of nowhere.
2015 YJ Of The Year
Thanks, but my rig is just a Prince among Kings. You folks gave me the answers to build it!
Burlbook48 is offline
post #12 of 12 Old 08-09-2010, 09:05 PM
Area.3.Fiftyone
Only problem is trying to cross drill a grade 8 bolt. It won't happen.
A spot on top with a little bit of weld on it to keep it from falling out would be your best bet and it would look totally stock.
TJ Door Hinge Pins - what to use? Just Jeff TJ Wrangler Technical Forum 16 11-27-2010 07:58 PM
Wrangler TJ full steel door hinge pins 06BlackRubicon TJ Wrangler Technical Forum 7 10-30-2009 03:54 PM
door hinge pins Wheelin90YJ YJ Wrangler Technical Forum 3 09-19-2007 01:19 PM
Door hinge pins Haik TJ Wrangler Technical Forum 4 03-10-2006 10:37 AM
Door hinge pins Haik TJ Wrangler Technical Forum 11 04-27-2005 04:56 PM
