Quantcast Full steel door help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Full steel door help
Old 12-18-2008, 02:01 PM   #1
mcohen
Somehow, something must have broke inside the passenger door on my jeep. The door handles are not opening the door. It feels like there is no resistance when pulling the handle on both the inside and outside. How do I get the door open so I can pull it off to fix it. Thanks for your help.
Mike
mcohen is offline   Reply With Quote
Old 12-18-2008, 02:28 PM   #2
the_mork
The inside door panel is easy to pull off, you can either work your fingers into it and pop the retainers (you'll break some but it will come off and new retainers are cheap) or you can run down to the parts store and get a door panel tool. The tool is pretty cheap and it looks like a screwdriver with a forked end. Once the panel is off you should be able to reach in and open up the door and also see what came loose.
the_mork is offline   Reply With Quote
Old 12-18-2008, 02:30 PM   #3
mcohen
Cool, thanks
Glock Forum
