full spool vs lock right locker - JeepForum.com
post #1 of 44 Old 01-24-2011, 04:33 PM Thread Starter
mmkcmoore
so im debating on putting a lock right locker or a full spool in my axles. i do offroad a lot but my jeep is also my daily driver. so just tell me which you would choose.
mmkcmoore is offline
post #2 of 44 Old 01-24-2011, 04:41 PM
Louie4
I would put a Lock-Right in the front. I would look at other options for a rear axle. I don't know if I would lock the D35 if I had to do it all over again.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 44 Old 01-24-2011, 04:47 PM
4.7stroker
I would not use a spool on the street ever. When you corner your outside tire has more distance to cover then the inside tire. A full spool will cause terrible road manners and if you have one in the front without a CAD or locking hubs or if you use 4wd on ice or snow you will be in the nearest ditch with the quickness.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #4 of 44 Old 01-24-2011, 05:00 PM Thread Starter
mmkcmoore
im just going to put one in the rear for now and its going on a dana 60 i have that ill put on my jeep once i get ready to be bolted in. so for now only the back will be done if that makes a difference
post #5 of 44 Old 01-24-2011, 05:01 PM
MLJeeper
MLJeeper's Avatar
As indicated above, spools arent a whole lot of fun on a daily driver. They can also be scary on the street in rain.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #6 of 44 Old 01-24-2011, 05:09 PM Thread Starter
mmkcmoore
i was thinking of prob doing the lock right anyway but i just hear that they are not good with 35s or bigger tires. i dont no if thats true or anything though
post #7 of 44 Old 01-24-2011, 05:38 PM
4.7stroker
A selectable locker is the best option. Me I have a LSD in the rear and a lockright in the front. A tight LSD is not as good as a locker however it works well on and off road and the locker in the front pulls me over most anything I come across here, I have never wished that I had a locker in the rear.
Dwayne
[url]
[url]
post #8 of 44 Old 01-24-2011, 05:41 PM
Krochus
While i would never concider spooling a DD I have been driving my locked 8.8 a great deal and honestly it isn't a quarter as dramatic as naysayers claim.
The ONLY time you can tell the rear is locked is (aside from massive traction offroad) when making a 90degree turn of greater such as at an intersection or when maneuvering at low speed such as in a parking lot. Out on the road in rain, snow or shine my jeep really drives no diffrent than it did with the open d35
Think Green recycle your YJ's sway and trac bars today!
Originally Posted by buickgnx88 View Post
"Jeep Wave threads, it's a newb thing, you wouldn't understand!"
Krochus is offline
post #9 of 44 Old 01-24-2011, 06:55 PM
MLJeeper
MLJeeper's Avatar
Neither is a good idea on the highway, but especially not a lincoln locked c clip axle
MLJeeper is offline
post #10 of 44 Old 01-24-2011, 07:02 PM
Krochus
Exactly how so?
I'll Keep that in mind when I figure out what these neblous "issues" I keep being told about finally decide to arise. I guess the main problem is my jeep doesn't have access to the Internet and therefore doesn't know it's supposed to flip upside down and burst into flames the moment one of my locked rear tires touch asphalt.
Krochus is offline
post #11 of 44 Old 01-24-2011, 07:07 PM
MLJeeper
MLJeeper's Avatar
Exactly how so?
When your welds crack and the dif comes apart on the freeway and your wheel takes off, maybe someone will be there to pull your smartass out of the flipped jeep and take you to the hospital. Like we did my friend. With any luck you wont kill anyone else.
MLJeeper is offline
post #12 of 44 Old 01-24-2011, 07:25 PM
badmax
jeepers guys!!! Ive had 2 mustangs with spools and 4:56 gears on the street. the road manners are not that bad except for very tight corners, expect to hear some tire talk! I didnt see a difference in the rain at all, But I cannot comment on snow. To each their own, but on a 50/50 rig I would see no problem with a spool
badmax is offline
post #13 of 44 Old 01-24-2011, 07:30 PM
MLJeeper
MLJeeper's Avatar
Ive run spools on the street, no its not that bad, it does add wear and it is trickier in the rain. If you can deal with the tire wear and take the time to get used to the rain its not that big of a deal no. Welded difs are great for offroad but they are potentially dangerous on the highway, Especially c-clip difs for obvious reasons.. Thats all im saying.
MLJeeper is offline
post #14 of 44 Old 01-24-2011, 07:32 PM
TSEJEEPERS
He is not talking about a Dana 35 or anything about Lincoln locking it.
Personally I would go with a full Detroit.
If it was a trail only, limited on road then yes a spool.
Reason I would not put a spool on a daily driver would be tire wear.
Large offroad tires are exspensive enough.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #15 of 44 Old 01-24-2011, 07:33 PM
parkerm26
Dwayne
Why wouldn't you want it to be spooled in the front? I'm curious because i'm considering one for my dana 60 front when i do my one ton swap pretty soon
93YJ 350-465-205, D60 and 14 Bolt, 40's http://www.jeepforum.com/forum/f22/yj-rustoration-1327569/
parkerm26 is offline
full spool in dana 60 mmkcmoore YJ Wrangler Technical Forum 1 01-22-2011 04:44 PM
Front spool with lock out hubs Solidkm TJ Wrangler Technical Forum 12 02-16-2009 02:39 PM
Full Spool Axle joburnet TJ Wrangler Technical Forum 6 02-13-2008 10:31 PM
Locker V. Spool V. Mini Spool yjdrvr YJ Wrangler Technical Forum 15 05-14-2007 06:06 PM
Full Spool jeepman14wheel TJ Wrangler Technical Forum 8 08-07-2005 12:59 AM
