Full Size Doors - Page 2 - JeepForum.com
post #16 of 32 Old 02-11-2013, 10:25 AM
Shadownwpa
Originally Posted by wrangler_bear View Post
I plan on contacting an auto body shop for a price quote.
... to have them do what? oil your latch?
Shadownwpa is offline
post #17 of 32 Old 02-11-2013, 10:37 AM Thread Starter
wrangler_bear
Lol...no. The windows roll down a little rough. Its probably something I can look at first. But....the light bar issue has to be resolved first to make sure I keep them.
wrangler_bear is offline
post #18 of 32 Old 02-11-2013, 11:41 AM
YJ4LIFE
The doors I bought for 750 are in decent shape. Color is perfect match to my jeep. Waxed them and they came out looking just as good as my jeep. The mechanics on the door might need oiling abd twinking. I plan on contacting an auto body shop for a price quote.
wd40 the crap of of them. they get gunky
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #19 of 32 Old 02-11-2013, 08:25 PM
StanF
WD40 is a good solvent for cleaning, but not a lubricant. WD-40 can be used to help clean the gunk, but you might want to put some clean grease on after that...
StanF is offline
post #20 of 32 Old 02-11-2013, 08:36 PM Thread Starter
wrangler_bear
I'm going to remove the light bar to see if the doors fit. Everywhere I've read says the doors should fit. The Doors came off of a 91 yj and I have a 93. once I'm sure that they will fit, I will start the cleanup process. I'll probably change a lot of the rubber strips on them.
post #21 of 32 Old 02-13-2013, 06:37 PM
Sparrows
Can you post some pics of the doors and the problem you're having? That would help a lot
Cheers
June '13 YJOTM
Sparrows is offline
post #22 of 32 Old 02-13-2013, 09:42 PM Thread Starter
wrangler_bear
post #23 of 32 Old 02-13-2013, 09:47 PM Thread Starter
wrangler_bear
This is it
post #24 of 32 Old 02-13-2013, 09:58 PM
rodgers3
What's the light bar made of?
Could take an angle grinder and put a notch in it so the doors fit?
rodgers3 is offline
post #25 of 32 Old 02-13-2013, 10:23 PM Thread Starter
wrangler_bear
You might compromise the sturdiness of the light bar
post #26 of 32 Old 02-13-2013, 10:26 PM Thread Starter
wrangler_bear
Once I get the door to close I hope the latch lock lineup. My Jeep is a 93 Wrangler. The doors come from a 1990 Wrangler. Everyone says they will fit. I hope so
post #27 of 32 Old 02-14-2013, 03:25 AM
Shadownwpa
Loosen all the screws holding it on and hold forward on it while you tighten it down. If that doesn't work take it off and slot the holes a little to get the play you need... shouldn't take much, start with the top hole on each side.
http://www.jeepforum.com/forum/f22/shadownwpa-91ish-yj-build-thread-1857154/
post #28 of 32 Old 02-14-2013, 01:46 PM
Sparrows
It looks like a type of ABS plastic to me. I was also going to suggest grinding a little notch in it. Shouldn't compromise it that much if at all.
Also this was going to be my other suggestion. Try loosening the bolts and just putting pressure on it to see how much slop you can get out of it before you re-drill the holes. If its not enough you can either cut a slot or just bore the holes maybe 1/8"-3/16" bigger and use a washer if need be. Maybe you could slot the top hole by cutting the slot on the rear side, and the bottom hole forward which should roll the top of it forward.... if that makes sense?
How did you soft uppers fit? Did they brush the light bar when closed?
Cheers
June '13 YJOTM
Sparrows is offline
post #29 of 32 Old 02-14-2013, 01:54 PM Thread Starter
wrangler_bear
Sorry I didn't answer your question. Light Bar is made of hard steel.
post #30 of 32 Old 02-14-2013, 01:56 PM Thread Starter
wrangler_bear
Door hits the bar and is unable to close.
