Full size Door outer door latch issue - JeepForum.com
post #1 of 3 Old 12-18-2011, 11:08 AM Thread Starter
andrew2641
Hey guys I bought a set of full Sahara doors to go on my 95 yj. the driver outer door latch broke so I replaced it yesterday only to have it brake after about 5 pulls. So obviously there is another issue adding strain to the lever arm. The inside handle works fine and pulls easy, however the outer definately feels stickier the few times it worked. Any ideas?
Thanks
andrew2641 is offline
post #2 of 3 Old 12-19-2011, 10:12 PM Thread Starter
andrew2641
[QUOTE="andrew2641"]Hey guys I bought a set of full Sahara doors to go on my 95 yj. the driver outer door latch broke so I replaced it yesterday only to have it brake after about 5 pulls. So obviously there is another issue adding strain to the lever arm. The inside handle works fine and pulls easy, however the outer definately feels stickier the few times it worked. Any ideas?
Thanks
post #3 of 3 Old 12-20-2011, 07:58 AM
GRYDE001
I'd take the door panels off and clean/lube all the inner parts. Then sit and watch all the inner parts working with the panel off and the door open. I just completely disassembled my doors for painting, it's not that hard. I bet it's sticking at the bottom of the door....
There's a part that resembles a long skinny "U" that attaches the outer door handle to the opening mechanism that might be binding.
once again...clean and spray with a white/lithium grease and see if it helps.
""Leave it stock, it will live longer. Just understand that its never gonna be as fast as a minivan""
GRYDE001 is offline
Full Door outer handle replacement - comb clips SolidBrass TJ Wrangler Technical Forum 5 12-29-2010 03:03 PM
Passenger door latch issue on half door Cards89YJ YJ Wrangler Technical Forum 5 03-07-2010 01:32 PM
Installing outer door handles, full door 2K TJ... BucJeeper TJ Wrangler Technical Forum 4 09-28-2006 08:21 PM
Removing Outer Door Handles On Full Doors? daren71 TJ Wrangler Technical Forum 6 03-10-2006 07:28 AM
Need Help with full door latch MainstreamJeep YJ Wrangler Technical Forum 4 10-14-2004 02:36 PM
