-   -   Full size Door outer door latch issue (http://www.jeepforum.com/forum/f12/full-size-door-outer-door-latch-issue-1302935/)
andrew2641 12-18-2011 10:08 AM
Hey guys I bought a set of full Sahara doors to go on my 95 yj. the driver outer door latch broke so I replaced it yesterday only to have it brake after about 5 pulls. So obviously there is another issue adding strain to the lever arm. The inside handle works fine and pulls easy, however the outer definately feels stickier the few times it worked. Any ideas?
Thanks
andrew2641 12-19-2011 09:12 PM
[QUOTE="andrew2641"]Hey guys I bought a set of full Sahara doors to go on my 95 yj. the driver outer door latch broke so I replaced it yesterday only to have it brake after about 5 pulls. So obviously there is another issue adding strain to the lever arm. The inside handle works fine and pulls easy, however the outer definately feels stickier the few times it worked. Any ideas?
Thanks
GRYDE001 12-20-2011 06:58 AM
I'd take the door panels off and clean/lube all the inner parts. Then sit and watch all the inner parts working with the panel off and the door open. I just completely disassembled my doors for painting, it's not that hard. I bet it's sticking at the bottom of the door....
There's a part that resembles a long skinny "U" that attaches the outer door handle to the opening mechanism that might be binding.
once again...clean and spray with a white/lithium grease and see if it helps.
The time now is 12:51 AM.
