full floating kits? - JeepForum.com
post #1 of 6 Old 05-03-2007, 10:53 PM Thread Starter
Git-R-Done
full floating kits?
I was looking at the full floating kits in my Q-tec magazine for the D35. how does this kit work, and how does it make the d35 stronger to hold up to more abuse and bigger tires?
Git-R-Done is offline
post #2 of 6 Old 05-04-2007, 05:28 AM
dell2028
dell2028's Avatar
Don't waste money on the D35. For the amount of $$$$ you'd be putting into the axle you can have a really nice set-up with an 8.8, D44, or a D60 (if you looked hard).
A full floater keeps the weight of the tires off the axle shaft. Meaning the shaft is now only using the torque from the driveline to turn the wheels. This is great if you have large diff components, but the D35 does not. Still gonna sheer ring and pinions, bend tubes, etc.
95 YJ, D30/8.8 w/ 4.88s, SOA, 35x14.50x16.5 Pit Bull Mud Dawgs, 101" Wheelbase, Custom Front Bumper, Winch, Custom Rear Tow Points, Traction Bar, Aussie Locker in front, 20 Gal. Gas Tank modification, Hurculiner Tub, Custom Rear Bumper, SYE and CV shaft, BTF Cross-over Steering, RCI 2191 fuel cell, BTF Rockers, RE 1.5" SOA springs up front and XJ springs in the rear
Down the line a bit...engine swap, the list goes on.
dell2028 is offline
post #3 of 6 Old 05-04-2007, 07:44 AM
bayvilleYJ
Agreed , the d35 is garbage in the shape of an axle. Upgrade , dont polish the terd.
bayvilleYJ is offline
post #4 of 6 Old 05-04-2007, 07:54 AM
ovrlnd
it uses a spindle with a double spline shaft. this kit is designed to "full float" your cash out of your wallet and give you a false sense of security. as posted above you can put a 8.8 or a 44 back there for the cost of that kit. after you swap it out you can cut down your 35 and turn it into a barstool or base for a coffee table.
"We'll get out of this disaster in time for the next one"
"I'm done recomboobulating the energy-mo-tron"
88 YJ, 350/350 Chevy, Twin Stick Dana 300 with JB 32 spline rear output, 6.5" lift, Front Scout II Dana 44 w/Yukon 4340 shafts, trac loc, 4.27's, Warn Premium Hubs, flipped YJ Tie Rod, Ford F150 front calipers, Rear Scout II Dana 44 w/Alloy 4340 shafts, HD RPT retainer plates, 4.27's True trac, Steeltech Disc brakes, Cage upgrade, B&M Prostick Shifter, Custom Fabbed tire, gas, jack carrier, 3/8 angle rear bumper, clevis's all around, old & reliable rep8000 winch. Flood lights. loud stereo. 35x12.50 swampers and a bunch of other stuff
ovrlnd is offline
post #5 of 6 Old 05-04-2007, 03:21 PM
dell2028
dell2028's Avatar
Now theres a use for it I hadn't thought of!
dell2028 is offline
post #6 of 6 Old 05-04-2007, 03:25 PM
Matt87YJ
Matt87YJ's Avatar
1987 YJ Wrangler
Boat anchor...
'87 Wrangler, Stroked with a few other toys...
Matt87YJ is offline
D30 = Full Floating?? Jim93YJ YJ Wrangler Technical Forum 3 08-13-2008 03:02 PM
Dana 44 Full floating axle kit Maynster TJ Wrangler Technical Forum 0 09-13-2007 03:27 PM
Full floating 35? terrible TJ Wrangler Technical Forum 2 03-11-2006 07:08 PM
Super 35, warn full floating kit phlex234 YJ Wrangler Technical Forum 36 09-28-2004 08:26 PM
just wondering about warn full floating knight TJ Wrangler Technical Forum 2 02-19-2004 12:03 AM
