Full Door Window question....searched no luck - JeepForum.com
post #1 of 7 Old 04-21-2010, 12:26 PM Thread Starter
Jsplurge
My question is, I am looking for the full doors, found one (passenger $100 no rust) but the vent glass is busted out, and the entire vent window track is expensive everywhere I've looked. So I thought what if you could put just a full piece of glass in and remove the vent track that goes from the top to bottom of the door, has anyone done this or can it be done and what is needed, any help or advice would be appreciated. Thanks.
-JG
95' Rio Grande, AX5, D30 Front/D35 Rear, all stock... for now.
Jsplurge is offline
post #2 of 7 Old 04-21-2010, 02:23 PM
youngYJ95
I've heard of guys using CJ vent glass panels because they don't open, and they didn't like the opening feature. Maybe you could find glass from a TJ and the corner piece and convert it b/c they should be the same dimensions since people are able to fit them on their YJ's.
[Originally posted by rulppa: But no, there is no change is power.. and my arse-dyno is pretty accurate]
youngYJ95 is offline
post #3 of 7 Old 04-21-2010, 02:35 PM
ziebartrob
Not to squash anyones idea, but it wont work man. Take it from a glass guy w/ a lot of years experience. The internal guides for the window and other dimensions are not set up for a single piece of glass. Also, on TJ it uses a "cable pull" type regulator, a YJ uses the old "bent arm sprocket" type. They are just too different. Have you tried any local junk yards? I wouldnt even suggest it here in the Rust Belt, but down in FLA you might find one in good shape.
Originally Posted by Mymmars
when your start to anthropomorphise your jeep into somthing above a dog and below a hooker
ziebartrob is offline
post #4 of 7 Old 04-21-2010, 02:46 PM
youngYJ95
Well it was worth a thought....anyways your best bet is to watch your local craigslist and ebay and hope for the best.
post #5 of 7 Old 04-21-2010, 02:58 PM
ziebartrob
OP, if and when you find your parts, let me know if you need any diagrams to help with install. I have some wicked new glass software that has GREAT pic's of the whole window assembly. Have to fax 'em, cause software wont let you "copy" pictures, but I got 'em if you need 'em.
post #6 of 7 Old 04-22-2010, 01:03 PM Thread Starter
Jsplurge
Thanks for all the input guys, guess I'll just have to splurge and buy the entire vent frame.
-JG
Jsplurge is offline
post #7 of 7 Old 04-22-2010, 01:28 PM
muddy93
1987 FSJ Wagoneer
I made a vent window for my passanger side door(similar situation, found hard doors, passanger side was missing all the glass). The frame for the vent glass was gone as well, all that was in the door was the seal for the vent window. I was able to cut out a piece of lexan, and fit it between the two "flaps" of the seal. It's not ideal, as I can no longer open that vent, but it's sealed up well enough that it's kept the rain out for the past 5 years.
Here's the best pic I could find, you can see that there is a little bit of hazing, but for a cheep fix, it worked out prety well.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
full door window question? griffsyj YJ Wrangler Technical Forum 7 07-07-2010 09:02 PM
Full door window issues czjeeper YJ Wrangler Technical Forum 3 10-22-2009 08:17 PM
Full Door Window Vibrates TJShadow TJ Wrangler Technical Forum 10 11-10-2008 05:32 PM
Full Door Window Access GoldenP51 TJ Wrangler Technical Forum 7 05-14-2008 10:46 AM
full door window rattles!!!! aaronswb2 TJ Wrangler Technical Forum 2 11-21-2005 05:37 PM
