Full door hinge torx bolt sizing - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Full door hinge torx bolt sizing
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-06-2015, 05:08 PM   #1
HB223
I stripped one of my torx bolts on my full door hinges and I need to know what size and length they are so I can replace it with a hex head. Its still in there otherwise i would measure it...
HB223 is offline   Reply With Quote Quick reply to this message
Unread 01-06-2015, 06:35 PM   #2
LoneYJranger
It's simple, two solutions
Remove one of the remaining 11 bolts on the door hinge and take it to the hardware store to match it,
Or
Since you still need to remove the stripped bolt, cut a groove on the head then apply lots of penetrant on it then use a big flat screwdriver to remove it
"Who put this thing together, Me"
"Who do I trust, Me"
With the help of jeepforum.com of course
LoneYJranger is offline   Reply With Quote Quick reply to this message
Unread 01-06-2015, 06:53 PM   #3
Schaef81
Can't use an extractor to extract the broken bolt? Not too difficult to do, just soak it with penetrating oil before doing it. Otherwise common sense says try loosening one of the other bolts to compare.....
BDS - Spartan - AtoZ Fabrication - Borgeson HD - USA Standard - BFGoodrich
Schaef81 is offline   Reply With Quote Quick reply to this message
Unread 01-06-2015, 08:50 PM   #4
HB223
Thanks for the input I kinda post things and then figure it out as i post them... most of the time.. gonna go with the extractor
Unread 01-06-2015, 09:31 PM   #5
LoneYJranger
Yeah, that's what it takes sometimes
Next time go to the bathroom mirror, tell yourself your problem to see if your inner self comes with the solution. Try it, you never know, it might work
Unread 01-06-2015, 09:46 PM   #6
HB223
haha is that some kinda yoga term? I got a t40 torx socket (a size bigger than what the bolt normally takes) and hit it in with a hammer and that did the trick.
Unread 01-07-2015, 09:01 AM   #7
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
What folks don't realise with those torx is they are painted. With the paint in the hole, the proper sized bit will not fit, so the next size down gets used. Give it some torque, the paint crushes and the bit spins out the socket.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 01-07-2015, 12:15 PM   #8
HB223
That's what i learned the hard way
