Fuel vapor lock? - JeepForum.com
post #1 of 5 Old 12-01-2009, 09:50 AM Thread Starter
circuit19
Fuel vapor lock?
On my 2.5 YJ (90) when I'm into the throttle climbing on the hwy's for any length of time my YJ starts losing power. If I stop and remove the gas cap there's alot of vacuum and it sucks air. Then when I get back into the thing it runs fine for a while until the next hill. Is this possibly cuz of a plugged fuel return line? ------------the fuel pump was looked at and checked out fine----
circuit19 is offline
post #2 of 5 Old 12-01-2009, 10:11 AM
Que89YJ
Vent line for the gas tank has to be pinched or the valve is bad. You can check the lines to the vapor canister the right rear corner. If you dont see anything wrong there then you are probably going to have to drop the fuel tank.
Que89YJ is offline
post #3 of 5 Old 12-01-2009, 10:33 AM Thread Starter
circuit19
OK, I understand the vent line part but what valve are you referring to and where is it located?
post #4 of 5 Old 12-01-2009, 11:11 AM
Louie4
There are two white fittings on top of your gas tank that vent the fumes and send them to the evap. canister. I'm not sure on your 2.5L where it would be.
Mine were kinked up when I dropped my gas tank. I replace all the vent lines before I put it back in.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #5 of 5 Old 12-02-2009, 01:19 AM Thread Starter
circuit19
louie4 thank you
Vapor lock anyone? usmcestep YJ Wrangler Technical Forum 0 04-27-2009 10:04 AM
Vapor Lock Bigdog05 TJ Wrangler Technical Forum 15 08-23-2007 03:48 PM
Vapor Lock???? why?? giggityjeeper YJ Wrangler Technical Forum 3 06-10-2007 07:02 PM
Vapor lock allmopar YJ Wrangler Technical Forum 2 03-13-2007 07:08 PM
Noisy fuel pump - vapor lock? Kev YJ Wrangler Technical Forum 0 06-26-2002 02:39 PM
