fuel tank will not fill and gas overflows - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > fuel tank will not fill and gas overflows
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNorthridge4x4 - Free ARB Air Compressor with Locker PurchaBds fox ipf 2.0 racing series shocks now available at rock
Unread 02-08-2010, 05:52 PM   #1
mebetech
Any one have a fix for not being able to fill my tank. I can get about 11 gallons in and then it shuts off or overflows. I have cleaned out the small vent tube in the wheel well area, but that was no help. Any suggestions???
mebetech is offline   Reply With Quote
Unread 02-09-2010, 06:45 PM   #2
ramo109
This happened with me, but it fixed when I started using nozzles with the cover such as these: http://comps.fotosearch.com/comp/DSN...r_~1775424.jpg
ramo109 is offline   Reply With Quote
Unread 02-09-2010, 07:37 PM   #3
MJMPC
Try pumping it in slower.
MIKE
http://www.dav.org/
MJM Powder Coating
Elizabethtown Ky.
http://www.cityprofile.com/
MJMPC is offline   Reply With Quote
Unread 02-09-2010, 07:53 PM   #4
dodger889
I have found that if I hold the gas nozzle at a certain position that mine will fill without kicking of until it is full.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline   Reply With Quote
Unread 02-09-2010, 09:17 PM   #5
burnout189
thats a yj thing . we have 4 yjs and they all do it. you have to **** the nozzle just right and it usually works. also some places the nozzles are different, some seem to work better then others.
lol. ok make the **** say tilt, it actually said c o c k, so it blocked it out on me... and i couldnt bring myself to just change it
A full sized Fleet of Jeeps
BARNHART'S AUTO REPAIR
burnout189 is offline   Reply With Quote
Unread 08-02-2010, 10:23 PM   #6
Anghil
Sounds like you were "c ock" blocked. I'm having a similar problem, except the fuel nozzle kicks after about 5 seconds, no matter what level the fuel is inside the tank. I've tried tilting it at different angle with very little success. Are there any fixes for this, or is it just something we all have to put up with?
Anghil is offline   Reply With Quote
Unread 08-03-2010, 03:23 AM   #7
dodger889
If you want to fix this do the TJ style filler. It's a straighter fill line. I have found that if I do not try to run the pump at full speed it will fill fine.
