Fuel tank skid | Belly up skid - JeepForum.com
post #1 of 10 Old 06-06-2009, 11:35 AM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
I noticed today that the stock gastank skid's heat shield portion (Running along the exhaust) is rusted 80% off and rattling. Is it advisable to remove this portion to stop the rattling, or should I leave it on until I can get an aftermarket (And beefier of course ) skid plate with a built in head shield ?
Also what is involved / needed for a belly up skid? Is it necessary to have a BL / MML for clearance? I really don't want to install a BL on my Wrangler, as I hate the appearance.
Thanks
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #2 of 10 Old 06-06-2009, 01:46 PM
machinehead131
Thanks
For the belly up you have a few choices.
make your own
kilby just made one they say no BL needed but unsure on clearance gains
AEV/Nth degree - expensive no body lift so they say but if you are standard i would get a 1"
Teraflex- 1" with auto and 2" with MT IIRC
You will most likely need an SYE and cv shaft if you don't go with the 1MML
Looking for TJ Rear Flares, if anyone has any please PM ME.
Thank you.
machinehead131 is offline
post #3 of 10 Old 08-23-2009, 05:14 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
Still curious on the gas tank skid / heat shield question. I removed the piece that is between the exhaust tip and the gas tank -- is that important enough to get a replacement gas tank skid with a built in heat shield?
-Matt
White '94 YJ Sport
UltimatE is offline
post #4 of 10 Old 08-23-2009, 05:19 PM
machinehead131
Mines been missing for a long time with no problems
Thank you.
post #5 of 10 Old 08-23-2009, 05:25 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Im in the process of Fabbing a Belly up for my YJ.
as of right now so far Ive installed a SYE, 1in BL, and 1in. MML. Tommorrow I'll be getting my bottles filled for my Oxy/Ace. torch setup and cutting the skidplate out of a 1/4" 4'x8' sheet hopefully I'll be done so I can get my XJ shaft cut down
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
post #6 of 10 Old 08-23-2009, 05:37 PM
jaw41272
jaw41272's Avatar
I would suggest replacing the skid, or at least patching yours in that area, if you bend the tail pipe while its hot, it could result in damage to the fuel tank, possibly but unlikely cause a fire as well. I never understood how so many people bent their tail pipes until 3 weks ago when I bent mine, easier to do than you think........
91 Sahara 4.0l Operation Welcome Home Parade Veh #69
PARADE JEEP MEMBER #1Auto posi-lok equipped, 4" susp. lift
K&N Drop in and loaded with battle scars
FOR SALE 2005 PT CRUISER CONVERTIBLE
2005 Suzuki DRZ400S For SALE
jaw41272 is offline
post #7 of 10 Old 08-23-2009, 05:40 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
My YJ will likely not see offroad use for a long time -- no funds to cover breakage or time to go at all. She's a road pounder for now
-Matt
White '94 YJ Sport
UltimatE is offline
post #8 of 10 Old 08-23-2009, 05:43 PM
yjjeepster
I wheel the crap out of my jeep with no heat shield on the gas tank skid. I have crushed the tail pipe on rock climbs on numerous occasions with no problems at all. Don't worry about it just rip it off.
95 yj 4.0 4" rc 33's. 8.8 rr, lockrights with 4.88's front and rear. warn xd9000i. tag, warn, hella, dynomax, optima
yjjeepster is offline
post #9 of 10 Old 08-23-2009, 05:43 PM
jaw41272
jaw41272's Avatar
Well then thats a decision you need to make for yourself, my personal thoughts are keep some sort of heat sheilding there, hot metal and plastic usualy results in melted plastic.... but thats all up to you
jaw41272 is offline
post #10 of 10 Old 08-23-2009, 06:49 PM
jenniferjeep
2010 JK Wrangler
Change out the gas tank skid plate. I bent my tail pipe and it melted my gas tank. It was parked in my garage a pouring gas on the floor with the door closed. Thank God my daughter told me before the house blew up.
jenniferjeep is offline
Weight Difference Between Stock Skid and Belly Up Skid pfifer TJ Wrangler Technical Forum 5 01-24-2010 07:38 PM
Teraflex Belly Up and Skid Row Engine Skid Compatibility jeepteejay TJ Wrangler Technical Forum 1 11-25-2009 08:24 PM
How to fix Fuel Tank Skid?? PanthersFan JK Wrangler Technical Forum 20 10-12-2009 07:15 PM
Fuel Tank Skid Bigboyky YJ Wrangler Technical Forum 0 04-07-2008 11:12 PM
fuel tank or Warn fuel skid rattling?? jomax77 TJ Wrangler Technical Forum 3 02-12-2007 04:08 PM
