Fuel Tank Modification ? - JeepForum.com
post #1 of 4 Old 04-26-2004, 06:09 AM Thread Starter
Six Shooter
Been gradually beating away at getting that vent tube out so I can shorten it. I think DC must have used a PVC cement when they installed it. I can not seem to get a good enough grip with needle nose pliers to pull the thing out. Just wondering what kind of problems I would create if I simply pushed the thing into the tank. I imagine the float for the fuel gauge would not like the company, but maybe it wouldn't be an issue. Thought's gentlemen???
Six Shooter is offline
post #2 of 4 Old 04-26-2004, 11:25 AM
4bangerYJ
I used a pair of vise grips. Once they were locked on it pulled out pretty easily. It took a bit of effort to get them to lock on since it is a tight fit.
I wouldn't push the tube inside the tank.
4bangerYJ is offline
post #3 of 4 Old 04-26-2004, 01:49 PM
BeatAChevy289
BeatAChevy289's Avatar
Yeah, I'd so no to pusing it in man. That tube isn't incredibly long or anything but say you push it in there and it touches the bottom of the tank before it gets out of the fill spout. Then you've got a bigger problem...you have a tube lodged between your fill spout and the bottom of the tank. Thats never good. He he, Later <><
1995 Firebird Formula, 6-speed, LT1 V8, t-tops, open exhaust. **In the For Sale section***
1966 Ford Mustang, Hi-Po 289 V8, 4:11's, I dare you to race me.
(different from the other link)
BeatAChevy289 is offline
post #4 of 4 Old 04-27-2004, 06:21 AM Thread Starter
Six Shooter
I finally got the thing out. What a pain in the arse. What was a seemingly easy project sure took it's fair share of time and effort. I'm lucky to have more than one vehicle to drive so I can chip away at these projects and not have to hurry. Thanks for the responses.
YJ - 15 to 20 Gallon Tank Modification Moxley YJ Wrangler Technical Forum 20 03-07-2014 11:21 PM
Gas tank access modification Grape Ape YJ Wrangler Technical Forum 14 02-15-2011 05:31 PM
Jeep gas tank modification bearhunter YJ Wrangler Technical Forum 8 08-13-2008 04:37 PM
Gas Tank Modification Question Six Shooter YJ Wrangler Technical Forum 6 04-23-2004 09:55 AM
15 to 20 Gal fuel tank modification question? kyousif TJ Wrangler Technical Forum 1 06-13-2003 11:58 PM
