Fuel tank - JeepForum.com
post #1 of 10 Old 11-12-2013, 03:44 PM Thread Starter
jasonjones21
Fuel tank
Could I get a 35 or 40 gallon gas tank in my Yj with 4" lift
jasonjones21 is offline
post #2 of 10 Old 11-12-2013, 04:20 PM
Randonexplosion
Deplorable
Randonexplosion's Avatar
I don't know of any that are even manufactured. Genright sells different tanks that bolt in the factory location but I just looked and the biggest one is only 20 gals. I just got their universal fuel cell that will mount behind the rear seat and it is 23 gallons. Why do want so large of a tank?
Randonexplosion is offline
post #3 of 10 Old 11-12-2013, 04:29 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
With losing the rear space behind the rear jump seat, you could install a second reserve tank. You would need to configure it inline with your original and work out the switching mechanism - I'm sure there are off-the-shelf parts for setting up a reserve tank like the full sized trucks sometimes have. If you've done the 20 gal tank mod, and add a 20 gal reserve tank, you could have the combined 40 gallons you want.
Question is: Who could drive a YJ for 600+ Miles without needing to stop to clear their head and stretch out their back?
91 YJ "Alice" 4.0L, AX-15, NP 231 w/HnT Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #4 of 10 Old 11-12-2013, 04:46 PM
TheBootlegger
Zombie apocalypse response Jeep? You got the .50 cals on yet? lol
TheBootlegger is offline
post #5 of 10 Old 11-12-2013, 05:32 PM
Randonexplosion
Deplorable
Once I install my 23 gallon cell I should be able to get well over 500 miles on a tank.
post #6 of 10 Old 11-12-2013, 05:41 PM
YJ4LIFE
i've seen pre-runner looking type of jeeps with gas tanks that extend beyond the rear crossmember.
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #7 of 10 Old 11-12-2013, 05:43 PM
Randonexplosion
Deplorable
Wouldn't be too fun to get rearended...
post #8 of 10 Old 11-12-2013, 05:54 PM
YJ4LIFE
the one i saw made a new tubular crossmember that held spare tires and whatnot.
YJ4LIFE is offline
post #9 of 10 Old 11-13-2013, 06:46 AM
Que89YJ
Que89YJ is offline
post #10 of 10 Old 11-13-2013, 07:26 AM
Old4X
1990 CJ7
There used to be a CJ tank that was 30 gal. It did not have a skid pan under it, but was very heavy gauge steel. IIRC, it had just a slight decrease in ground clearance when installed.
It would fit a YJ with a 4.2 engine, probably not one with fuel injection.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
