fuel tank - JeepForum.com
post #1 of 9 Old 07-13-2010, 11:15 AM Thread Starter
lasg4
fuel tank
Has anybody used a non efi tank with efi. The non efi has no baffle. Any imput?
lasg4 is offline
post #2 of 9 Old 07-13-2010, 12:06 PM
Que89YJ
The baffels dont matter unless your angled/banked hard and very low on fuel. Getting the fuel pump to fit that has the right pressure is a bigger issue. Why would you want to replace the larger capacity plastic tank with the steel one? What do you have in mind?
Que89YJ is online now
post #3 of 9 Old 07-13-2010, 01:13 PM Thread Starter
lasg4
Tank is leaking and it has a metal tank. The threads I have read they all are 20 gallon tanks just set up different
lasg4 is offline
post #4 of 9 Old 07-13-2010, 01:35 PM
AZoriginal
If you're going to replace your tank, just make sure you match the new one up to the model year of your jeep so you're ensured the fuel pump will mount correctly. Don't worry about the plastic baffle in the OEM tank. After market doesn't come with it. If you can get a 20 gallon for your year, so much the better. I did and I'm glad.
Never, Never, Never Give Up
Winston Churchill
AZoriginal is offline
post #5 of 9 Old 07-13-2010, 01:39 PM Thread Starter
lasg4
The pump is not in the tank. I'll go with the no baffle one thanks.
lasg4 is offline
post #6 of 9 Old 07-13-2010, 01:43 PM
wickedoffroad
1987 YJ Wrangler
not all yj came with a 20 gallon. just picked up another 87 and was surprised when i filled it up that it only took 3 gallons. looked under and surprise....10 gallon tank.
wickedoffroad is offline
post #7 of 9 Old 07-13-2010, 01:58 PM
Que89YJ
No, the pre 91 Yj's have a metal tank. You might not even need to replace it. You need to and see where its leaking from. It could be a bad vent or a clamp. You can also use the epoxy repair designed just for gas fuel systems thats available at any good auto parts store.
Read this: http://www.jeepforum.com/forum/f12/h...emoval-981049/
If the tank is truely beyond repair you can buy a plastic one cheap because they were used on so many Yj's and they doen't rust.
Read this: http://www.jeepforum.com/forum/f12/p...-4-2l-1043678/
post #8 of 9 Old 07-13-2010, 02:06 PM
NonRubicon
How many Jerry cans were rigged up on that thing?
NonRubicon is offline
post #9 of 9 Old 07-13-2010, 02:26 PM
remmons
I was one of the lucky ones to already have the 20 gallon poly tank on my Jeep when I did the EFI conversion. All I had to do was to buy a electric pump/sender unit assembly and go. The wires are already ran back there for the electric fuel pump (for the 2.5L fuel injected engines).
(I did have to purchase another tank as that mine had a crack in it from the P.O.)
Robert.
remmons is offline
Fuel leaks from top of fuel tank on cool mornings.....why? jeepdrvr69 YJ Wrangler Technical Forum 4 06-30-2009 12:57 AM
Major vacume in fuel tank causing fuel to spill out bigredcherokee YJ Wrangler Technical Forum 2 09-28-2008 03:35 PM
87 YJ fuel tank and lines running to fuel pump 87yjjeep YJ Wrangler Technical Forum 2 05-27-2007 04:07 PM
fuel tank or Warn fuel skid rattling?? jomax77 TJ Wrangler Technical Forum 3 02-12-2007 05:08 PM
Help! Lock nut on fuel tank for fuel pump H8PVMT TJ Wrangler Technical Forum 6 07-16-2004 01:21 PM
