Fuel system Help, please - JeepForum.com
post #1 of 11 Old 01-07-2009, 07:03 PM Thread Starter
cashking63
I have an 89 Wrangler I picked up used. I replaced the fuel tank. when i did there are 3 small hoses coming off of the tank on the passenger side. one of these goes to a T fitting and then goes to a small filter looking part. It all looks as if it has been hodge podged together and the filter like thing has a hole burned in it. I have taken it to several parts dealers and a couple mechanics and no one can identify it or even tell me what it is for. So, here I am pleading to you, the Jeep gods, can anyone tell me what it is and where to get it?
cashking63 is offline
post #2 of 11 Old 01-07-2009, 07:06 PM
J33Pyj
the 2 little filter looking things i believe are the rollover pieces to cut off fuel flow if you should rollover. Hopefully someone will chim in that knows for sure
90 yj/ 4:88 gears/33x12.50x15 Super Swamper TRXUS Mud Terrains/K&N air system/2.5L/D30front aussie equip'd/D35 rear / 3in BL/ 2in shackle lift / XRC8 Winch
If you havent broken it, you havent been wheelin
J33Pyj is offline
post #3 of 11 Old 01-07-2009, 07:09 PM Thread Starter
cashking63
hmm, so there are supposed to be 2? that would explain the t and the way it looks to be rigged
post #4 of 11 Old 01-07-2009, 07:10 PM
JJ-4
JJ-4's Avatar
1987 YJ Wrangler
do you got any pics of it. It might be the rollover as said above is it pushed in on the corner of the tank. should be 2 total on each side of tank
87 YJ, 07 JK 5.3 Vortec
Firefighters Jeep Club
p_Club
JJ-4 is offline
post #5 of 11 Old 01-07-2009, 07:11 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Read here.
http://www.jeepforum.com/forum/showt...ight=fuel+vent
Does it look like the pic in the link?
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #6 of 11 Old 01-07-2009, 07:17 PM Thread Starter
cashking63
yup! that is it! You guys rock! now I just have to track down 2 new ones
post #7 of 11 Old 01-07-2009, 07:28 PM
Gonewhln
Autozone is what one member said he got his at.
Gonewhln is offline
post #8 of 11 Old 01-07-2009, 07:34 PM Thread Starter
cashking63
lol, they are one of the ones that looked at me like i brought them a part from the Lunar lander, but i will try again. Again, thanks for all the help guys
post #9 of 11 Old 01-07-2009, 07:39 PM
ctm
There's only one rollover valve. Two vent lines come off the tank on the passenger side. They Tee together into a steel line that goes up to the rollover valve. The line coming off the top of the rollover valve goes to the canister on the firewall, that line being one of three fuel related lines going from the engine bay along the frame rail .
ctm is offline
post #10 of 11 Old 01-08-2009, 11:53 AM
J33Pyj
mine has 2 valves one on each side of the tank my tank is from a 94 wrangler my OEM tank from 90 only had 1
J33Pyj is offline
post #11 of 11 Old 01-08-2009, 07:31 PM
ctm
so the OP has an 89 he should have 1, not 2, right?
ctm is offline
Fuel in PCV/CCV system silentsam YJ Wrangler Technical Forum 0 12-18-2009 03:03 PM
2.5l fuel system cwbymt1973 YJ Wrangler Technical Forum 2 11-21-2009 12:59 PM
Fuel filter replacement - How do I depressurize fuel system? Rproject YJ Wrangler Technical Forum 13 11-23-2008 08:34 AM
?????YJ v8 fuel system????? 89YJv8 YJ Wrangler Technical Forum 6 08-14-2008 04:05 PM
Fuel System?! blase116 TJ Wrangler Technical Forum 0 10-31-2006 08:43 PM
