fuel smell? - JeepForum.com
post #1 of 9 Old 01-19-2014, 02:15 PM Thread Starter
cody413
fuel smell?
I have a 92 Wrangler with the 2.5. I changed injectors to the 5.0 yellow cap injectors with the four hole. Seems to run better. But every time I down shift or come to a stop and put it in neutral it has a bad fuel smell. I don't remember if it did before I swapped them. I've had them in for months now. Anyone know what it could be?
cody413 is offline
post #2 of 9 Old 01-19-2014, 02:18 PM
ddferdt
Running rich probably, I don't have a remedy. Mines doing the same, I just left it since it's getting ripped out anyways
ddferdt is offline
post #3 of 9 Old 01-19-2014, 02:56 PM Thread Starter
cody413
I think it's running rich too. I just didn't know if I had to do anything since the new injectors were added. Might be pushing to much gas in. Mine will be ripped out too but not for a while. Still building up my 350
cody413 is offline
post #4 of 9 Old 01-19-2014, 03:28 PM
Que89YJ
Do the basics. Check the fuel pressure and the fault codes. Check the o2 sensor. Check the evap and tank vent lines. See if you smell it in the exhaust. Bad catalyst.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #5 of 9 Old 01-19-2014, 07:03 PM
pasinbuy
Get under your rig a sniff around. The rubber hoses are pretty old by now and may have split. I would start sniffing around the rear of the rig first.
If your nose has a hard time finding the leak, sniff some coffee grounds or beans to clear up the nostrils and continue sniffing around. Some times gas smell takes over the area.
Smelling gas is bad so be careful in your search.
pasinbuy is offline
post #6 of 9 Old 01-20-2014, 03:56 PM Thread Starter
cody413
ut do you think it will still smell like gas by the time I stop. It's only happens for a min or two when I downshift or out in neutral . By the time I stop it's gone
cody413 is offline
post #7 of 9 Old 01-20-2014, 05:22 PM
Que89YJ
No cat? Check you evap and vent lines.
Fault codes:
No Start:
Que89YJ is offline
post #8 of 9 Old 01-20-2014, 11:10 PM
RCwheelin
same thing is happening with mine, didnt know where it was coming from until i glanced at the top of my muffler, there was a nice hole the size of a dime exiting the muffler.
93' YJ
RCwheelin is offline
post #9 of 9 Old 01-21-2014, 07:21 AM Thread Starter
cody413
I've been busy the last couple days. I hope to get under it today and will start looking around. If anyone has any thing else they could think of id appreciate it. Thanks guys and gals
cody413 is offline
fuel
