Fuel Sending unit replacement Question - JeepForum.com
post #1 of 10 Old 06-29-2011, 09:29 AM Thread Starter
Jims-87YJ
1987 YJ Wrangler
Just picked up a new Fuel sending unit for my rebuild and have a question, when using the rubber gasket on the top should i seal it with something (RTV-?) or is just the rubber seal good enough?
Also is there any calibration that I should do before I assemble it?
Thanks for any info.
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
post #2 of 10 Old 06-29-2011, 10:29 AM
oldtime_ironman
I don't think its absolutely necessary, but it couldn't hurt either. I used a very thin coating of Permatex #2 (the black tar stuff). There isn't any calibration that I'm aware of, although I would check to be ery sure that the grounds are good.
oldtime_ironman is offline
post #3 of 10 Old 06-29-2011, 02:57 PM
pasinbuy
If you want to be able to go back in without buying a new gasket. Do not use RTV. It is a thick gasket.
pasinbuy is offline
post #4 of 10 Old 06-29-2011, 03:17 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Gasket should be fine on it's own and there is no calibration needed.
5.7YJ is offline
post #5 of 10 Old 06-29-2011, 03:30 PM
phil1330
1964 CJ5
NO rtv. Rubber gasket is A OK by itself.
"Life is hard, it's harder if your're stupid"...The Duke
phil1330 is offline
post #6 of 10 Old 06-29-2011, 05:42 PM
gunshw301
rtv is no good with fuel, even says it on the label.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #7 of 10 Old 06-29-2011, 08:28 PM
Noltz
YJ Wrangler
No silicone here. Make sure you add a sending unit access hole to the bed of your project.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4" & shackles, BFG 33's (sold)
Noltz is offline
post #8 of 10 Old 06-29-2011, 08:33 PM Thread Starter
Jims-87YJ
1987 YJ Wrangler
Thanks for all of the replies. Will install just the gasket, as I am replacing all of the hardware and sandblasting and painting everything, if I have to drop the tank down the road it should not be an issue. Thanks again, Jim
My build thread:
post #9 of 10 Old 06-29-2011, 09:15 PM
jcmooreusmc
Jim, glad to hear you're going with the gasket only. I'll give you an example of what that silicone or rtv will do. I had my fuel pump replaced at a shop by a licensed mechanic. Later on, I was having trouble with the jeep shutting off while driving for a good hour or more. After sitting for a few hours, it would crank and run again. Decided to drop the tank and check out the pump. The mechanic put a tremendous amount of silicone around the hole for the sending unit. Silicone + Gasoline = Jelly. The jelly would get sucked up around the screen and stop fuel flow. After sitting, it would fall off and drop back to the bottom of the tank. Had a good handful in there. I wound up replacing it with a Bosch and did the work myself.
jcmooreusmc is offline
post #10 of 10 Old 06-29-2011, 09:54 PM Thread Starter
Jims-87YJ
1987 YJ Wrangler
Wow That sounds like a mess, I will avoid the use of any additional sealant. Thanks again for all the replies
My build thread:
Fuel sending unit replacement Towny72 YJ Wrangler Technical Forum 9 10-05-2010 10:16 AM
Fuel sending unit replacement? houseyj YJ Wrangler Technical Forum 2 05-17-2009 11:28 AM
'90 YJ Fuel sending unit question rwcook49 YJ Wrangler Technical Forum 0 07-13-2008 07:57 PM
Fuel Sending Unit Question Duckhat YJ Wrangler Technical Forum 8 10-23-2006 11:44 AM
20 gallon Yj fuel sending unit replacement help cueball YJ Wrangler Technical Forum 2 08-19-2006 08:40 PM
