***Fuel Sending Unit Question*** - JeepForum.com
post #1 of 4 Old 02-03-2011, 09:35 AM Thread Starter
Squamer
Here's a good noodle exercise......
I currently have a 1990 2.5l TBI with a 15 gal steel fuel tank with electrical fuel pump.
I have acquired a 20 gal poly tank from a 1989 4.2l that had a mechanical fuel pump (sending unit just has fuel pickup, vapor return, and fuel level/float hardware)
The question is....how to I integrate a 2.5l TBI fuel sending unit into the 20 gal poly tank? Now obviously it's not a direct swap. Does anyone know what 15/20 gal poly tank fuel sending units are compatible with a 2.5l TBI? I am also aware that the fuel pumps for fuel injected models are different from TBI models and will not be a direct replacement. (TBI= pumping 40psi regulated down to 14 psi. FI= pumping 100psi regulated down to 40 psi) Is there a possibility of taking a later model FI sending unit and swapping in a fuel pump from a TBI?
I'm lost. Has anyone traveled this road before?
Red Jeep Club: 584 BTW-There are no mechanical problems which cannot be solved through suitable application of high explosives.
JeepLife...all day, every day!
it out. Support your hometown.
Squamer is offline
post #2 of 4 Old 02-03-2011, 10:38 AM
Que89YJ
You have a 1989 Poly tank out of a 4.2L? What shape is the acess to the tank? You would actually be better off selling it off and get a complete tank with the sending unit for a 91-95. It is a direct swap. No problem with the pressure regulator. I have a tank ready to go into mine as soon as the weather breaks.
Que89YJ is offline
post #3 of 4 Old 02-03-2011, 11:31 AM Thread Starter
Squamer
Originally Posted by Que89YJ View Post
You have a 1989 Poly tank out of a 4.2L? What shape is the acess to the tank? You would actually be better off selling it off and get a complete tank with the sending unit for a 91-95. It is a direct swap. No problem with the pressure regulator. I have a tank ready to go into mineas soon as the weather breaks.
Correct. The access to the tank is rectangle in shape.
So all I need is a fuel sending unit from a 91-95? Does it matter if it is a 2.5 or a 4.0?
Squamer is offline
post #4 of 4 Old 02-03-2011, 12:53 PM
Que89YJ
Que89YJ is offline
fuel , poly , sending , tank , YJ
YJ Fuel Tank/Sending Unit Question arnot YJ Wrangler Technical Forum 0 01-29-2011 02:38 PM
Fuel sending unit question Selafane YJ Wrangler Technical Forum 0 06-08-2009 12:24 PM
'90 YJ Fuel sending unit question rwcook49 YJ Wrangler Technical Forum 0 07-13-2008 07:57 PM
Question about fuel sending unit ? DaSham58 YJ Wrangler Technical Forum 0 09-16-2007 04:34 PM
Fuel Sending Unit Question Duckhat YJ Wrangler Technical Forum 8 10-23-2006 11:44 AM
