Fuel Sending Unit (Part Problem) - JeepForum.com
post #1 of 3 Old 02-28-2012, 07:59 AM Thread Starter
USMC-0311
I have a 1991 Wrangler that had been sitting for a while because It was mis-diagnosed.. Anyways I just recently got back from Afghanistan and I want my baby fixed so I can get dirty again. So it came to be that my fuel pump was in terrible shape so I am in the middle of replacing it.. Here is the problem, I need a little black piece that attaches to a little pipe on the end to keep the line from draining when the engine is turned off, it may be called a "stopper". It turned to mush on account of sitting so long without use, I am assuming this. I need help finding one because I have had no luck. I would appreciate anything that turns up. Thanks.
USMC-0311 is offline
post #2 of 3 Old 02-28-2012, 08:29 AM
Jeepsr4me
Think that is the return line. Stopper just directs the fuel to bottom of tank to keep air bubbles and such from straying all over. it should set in a little cup. I have used a piece of hose to direct it in there.
Jeepsr4me is online now
post #3 of 3 Old 02-28-2012, 08:49 AM Thread Starter
USMC-0311
Okay awesome, I will give that a try and see how it does. Thanks alot!
1991 yj , fuel , sending unit , stopper
Fuel Sending Unit problem COYJ TJ Wrangler Technical Forum 2 11-24-2010 11:35 AM
What fuel sending unit?? 87 Wrangler 4.2 mechanical fuel pump 20 gallon tank Chris Aunchman YJ Wrangler Technical Forum 1 08-27-2010 03:54 PM
91 YJ Fuel Sending Unit problem Grizz91YJ YJ Wrangler Technical Forum 0 03-15-2009 06:52 PM
Need help finding a Sending unit part # Barrio Wrangler General Discussion 2 10-07-2008 10:19 PM
Fuel Sending Unit/Pump - 1 unit in an 89? saxsan YJ Wrangler Technical Forum 3 10-01-2007 11:48 AM
