Fuel Sending Unit - Page 2 - JeepForum.com
post #16 of 21 Old 02-04-2013, 08:02 AM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
I've been having this problem for years too, but finally fixed it a few months ago. I don't necessarily recommend this procedure, was not the easiest, but I like it.
I suspected the problem was in the tank, not the dash, and this got confirmed when I swapped the whole dash for a custom and used a new Autometer gauge. I also know that it's a pain to drop the tank all the time to slightly bend the float arm while trying to get the numbers right. So, I made a nicely done access panel in the floor of the rear bed of the tub. Over about 3-4 tanks of gas and minor adjustments to the float via the new access panel, I'm good. As a start, I used a potentiometer (variable resistor, from signal line at tank to ground) so I knew exactly what ohms were needed to get the gauge to read at the 5 main points (E/.25/.50/.75/F), then played with the float assembly on the bench to get those ohm readings close. The gauge now reads dead on 'E' when I have 3 gallons left, and takes 17+ to fill. It's not dead on linear at the mid points, but it's decent.
0
So, I can tell you that enough playing with bending the float can make it work.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #17 of 21 Old 02-05-2013, 02:58 PM
rockywrangler
Originally Posted by bluedeval03 View Post
Rocky, I can tell you, because mine kept doing the exact same thing, that the filter sock on the bottom of the sending unit has come off. I have a '90 and the fuel pump has been replaced 4 times now. This last time I pressed the metal tabs that hold the sock on for a tighter fit, and I also used a couple of zip ties to make sure it doesn't fall off again.
ya know now that i think about it mine didn't have a filter sock on it when i pulled it
rockywrangler is offline
post #18 of 21 Old 02-05-2013, 03:07 PM
rockywrangler
Originally Posted by Northinger View Post
Here is some specs, hopefully you can read it.
NORTHINGER...THANKS
that helped out alot i can read the first one and that one made the difference. I had already checked resistance(ohm) in sending unit and it reads 1.0 to 94.5 .... obviously empty to full
so that solved it i have got to have an open to ground....
post #19 of 21 Old 02-05-2013, 06:35 PM
Que89YJ
The ground is shared with the fuel pump. If the ground was bad the fuel pump wouldn't work. That is the full range of the sender unit. It sounds good not bad.
Que89YJ is online now
post #20 of 21 Old 02-05-2013, 09:06 PM
rockywrangler
ahhh man why did i have to know that... thanks though...... i had my hopes up, pointed to it guess it is off to the dash and start checkin there
post #21 of 21 Old 08-21-2015, 09:21 AM
Backfire01
Left turn
Originally Posted by rockywrangler View Post
jeep cuts out when i make a left turn only when my gauge reads close to a 1/4 tank... my gauge hasn't exactly works right it bounces ALOT... any suggestions ... i am dropping the tank tomorrow to check for ground issues and see if the float is messed up on sending unit....
thanks for any suggestions
by the way it is an 89 yj 2.5l
My '89 YJ 2.5 did the same thing.
Solder was broken around the pickup tube allowing fuel pump / sending unit, to swing around inside tank.
Backfire01 is offline
fuel gauge , fuel level sensor , fuel pump assembly , fuel tank
What fuel sending unit?? 87 Wrangler 4.2 mechanical fuel pump 20 gallon tank Chris Aunchman YJ Wrangler Technical Forum 1 08-27-2010 04:54 PM
89 Fuel Sending Unit 73Dart YJ Wrangler Technical Forum 8 10-02-2009 11:25 PM
1998 TJ wrangler - fuel pump sending unit / fuel gauge drummerchukb1 TJ Wrangler Technical Forum 3 05-11-2009 05:42 PM
Fuel sending Unit on 98 TJ paine TJ Wrangler Technical Forum 15 01-21-2009 10:10 AM
Fuel Sending Unit/Pump - 1 unit in an 89? saxsan YJ Wrangler Technical Forum 3 10-01-2007 12:48 PM
