Fuel Sending Unit - JeepForum.com
post #1 of 21 Old 05-19-2012, 08:35 PM Thread Starter
acetylcholine
Fuel Sending Unit
Does anyone know why it is so hard to find a fuel sending unit for a 1993 YJ? The fuel guage has never worked in my YJ (only had it one month). To make a long story short, I have narrowed the problem down to the sending unit. I dropped the tank, pulled the sending unit and pump out. Since I have gone to all this trouble, I want to replace both the sending unit and the pump while the tank is down. Fuel pumps are plentiful at my local parts stores, but the sending unit doesn't exist. I have found online on quadratec for a 20 gal tank (MTS brand), but don't like ordering parts I can't see. I think I have a 20 gal tank, but not sure since I never knew how much was in tank. Any advice would be great.
acetylcholine is offline
post #2 of 21 Old 05-19-2012, 08:43 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
All '91 & newer tanks are the same, regardless of capacity. The 15 to 20 gallon modification is well documented.
www.mtscompany.com
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 21 Old 02-01-2013, 10:17 PM
rockywrangler
jeep cuts out when i make left turn
jeep cuts out when i make a left turn only when my gauge reads close to a 1/4 tank... my gauge hasn't exactly works right it bounces ALOT... any suggestions ... i am dropping the tank tomorrow to check for ground issues and see if the float is messed up on sending unit....
thanks for any suggestions
by the way it is an 89 yj 2.5l
rockywrangler is offline
post #4 of 21 Old 02-02-2013, 12:59 AM
ROTTEN
Try and avoid left turns if possible
No seriously its very common to have your yj fuel gauge not working correctly. Mine stops at 1/8
I would put a few gallons in and mark that as empty. Then add more and watch your miles. Underestimate your mpgs.
Or change your sending unit/float/pump
I'm new
ROTTEN is offline
post #5 of 21 Old 02-02-2013, 08:09 AM
Que89YJ
The bottom of the pump has a pickup that sometimes drops. The only way you are going to know for sure is to drop the tank and look. You could take it as an oportunity to find a used tank and straps and skid plate from a 91-95 poly tank. They are direct bolt ins and you get an extra 5 gallons.
Que89YJ is offline
post #6 of 21 Old 02-02-2013, 08:23 AM
jokerchief462
Mine does it on long turns or hill climbs. I just get gas real quick or stop and drop 5 in the tank. Range with a YJ is some thing I am getting used to it has become a major planning factor for off road trips with the club.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #7 of 21 Old 02-02-2013, 10:37 AM
kahanabob
kahanabob is offline
post #8 of 21 Old 02-02-2013, 11:07 AM
Que89YJ
It's the wrong pump. He has the 87-90 tbi setup. That pump is for the 91-95 poly tank.
Que89YJ is offline
post #9 of 21 Old 02-02-2013, 09:11 PM
rockywrangler
that is correct I do have tbi... so a 91-95 tank is a 20 gallaon and is a direct fit??? i understand if the gauge was close but i know it never gets that low that i am running out... the gauge WILL get fixed i am determined lol.... thanks again fellas
post #10 of 21 Old 02-02-2013, 09:41 PM
Northinger
Im not sure if the sending unit is the same as my 93. But i had the same issue with my gauge. Dropped the tank, and pulled the pump, the metal slide the float runs on gets too much resistance. I took some fine grit sand paper and got it down to the correct resistance about. I forget what exactly the numbers are, but it was the problem. You might want to go just a little extra because when I put the unit back together, my gauge would cut off at around 5/8 tank. While your down there you might want to check the gasket, i forget what years the recall is for but I had that issue with the gasket cracking.
Northinger is offline
post #11 of 21 Old 02-03-2013, 02:25 PM
rockywrangler
i dropped the tank today had easily 1/4 tank left... so after emptying it i cleaned pump off and did a resistance test with ohmmeter... now i need to find specs.. but low fuel 1 ohm and full tank 94 ohms... but i figured since tank was out to tap into ground wire and re-ground it at the male/female adapter for fuel pump... any ideas????
as far as the float side having to much resistance? to heavy you mean? but i did make sure it did not have a hole in it (placing it in water)... kinda clueless so i was gonna try the ground..
post #12 of 21 Old 02-03-2013, 02:52 PM
rockywrangler
hey there guys... does anyone have the website to get specs on that fuel sending unit.... i apparently am lookin in the wrong place...
post #13 of 21 Old 02-03-2013, 02:56 PM
Que89YJ
http://www.mtscompany.com/jeep.htm
Go down to the bottom. The unit selection is on the right. Make sure you select the right year and fuel injection.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #14 of 21 Old 02-03-2013, 03:45 PM
bluedeval03
Rocky, I can tell you, because mine kept doing the exact same thing, that the filter sock on the bottom of the sending unit has come off. I have a '90 and the fuel pump has been replaced 4 times now. This last time I pressed the metal tabs that hold the sock on for a tighter fit, and I also used a couple of zip ties to make sure it doesn't fall off again.
bluedeval03 is offline
post #15 of 21 Old 02-03-2013, 05:26 PM
Northinger
Here is some specs, hopefully you can read it.
fuel gauge , fuel level sensor , fuel pump assembly , fuel tank
What fuel sending unit?? 87 Wrangler 4.2 mechanical fuel pump 20 gallon tank Chris Aunchman YJ Wrangler Technical Forum 1 08-27-2010 03:54 PM
89 Fuel Sending Unit 73Dart YJ Wrangler Technical Forum 8 10-02-2009 10:25 PM
1998 TJ wrangler - fuel pump sending unit / fuel gauge drummerchukb1 TJ Wrangler Technical Forum 3 05-11-2009 04:42 PM
Fuel sending Unit on 98 TJ paine TJ Wrangler Technical Forum 15 01-21-2009 09:10 AM
Fuel Sending Unit/Pump - 1 unit in an 89? saxsan YJ Wrangler Technical Forum 3 10-01-2007 11:48 AM
