Quantcast Fuel Savings - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Fuel Savings
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 05-08-2007, 11:07 PM   #1
dand3053
Fuel Savings
Anyone ever install aftermarket fuel saving items? such as a throttle body spacer or the Tornado Fuel saver...Also, i keep seeing threads about upgrading to a GM HEI ignition. What are the benefits of this?
dand3053 is offline   Reply With Quote
Old 05-08-2007, 11:14 PM   #2
drexelsteve
Well from what i've seen on tv you should get at least 10 more mpg with the tornado. I haven't seen any throttle body spacers on tv so i can't help ya there. You could also look into the magnetic fuel saver that clips onto your fuel lines. JCWhitney says that it magnetically aligns the "gas" molecules and helps them burn more efficiently. That ought to be good for a few.
84 cj7, drives like a dump truck
drexelsteve is offline   Reply With Quote
Old 05-09-2007, 12:43 AM   #3
Axl Jack
If your Jeep is fuel injected, skip the throttle body spacer. Won't make a lick of difference.
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline   Reply With Quote
Old 05-09-2007, 12:52 AM   #4
DUNES
those tornados and magnets and gizmo's have all been tested and not one has shown to improve anything.
jury is out on throttle body spacers for me, on a mpi motor it will do nothing. on a tbi , some who have them say they work but i'm not sure if it's wishful thinking or a reality. i have seen alot of claims for these things but personally woudn't bother.
unless the stock ignition is either poorly designed or not functioning correctly, i don't think theres much to gain by an aftermarket. i don't speak from experience on jeeps but i've built quite a few cars, bikes, quads, trucks and have not yet found a stock ignition to be so lacking that i'd replace it, that is unless it's shot, then by all means, upgrade.
DUNES is offline   Reply With Quote
Old 05-09-2007, 06:47 AM   #5
Tulsachokehold
the easiest way to up your fuel economy, is not exactly a cheap one. Buy a Honda and dont drive the Jeep as a DD.
'91 YJ. 4.0 TF999, D300 w/ 4:1, twin sticks. Chevy D44 front, 4.10's, spooled, Yukon 4340 shafts w/ super joints. Warn premium lock outs, High steer, ram assist. Dodge D60HD rear, 4.10's, welded, disc brakes. SOA front w/ RE 1.5" SOA leaf packs. Custom 4 link rear w/16" fox air shocks, stretched to 110". 38x12.5x15 TSLs on crager Nomads w/ DIY beadlocks. Tolly Fab Tube fenders, rocker gaurds, cage. 15gal stainless steel fuel tank.
Tulsachokehold is offline   Reply With Quote
Old 05-09-2007, 06:50 AM   #6
mfalik
mfalik's Avatar
There was an article in Popular Mechanics where they tested a bunch of those bolt on gimics. The Tornado actually hurt performance (reduced peak horsepower by 10%), and didn't significantly change fuel consumption.
MichiganTech Mechanical Engineer Alumni
1994 Wrangler Sahara - Jeep Project
2003 Dodge Ram 1500 (new truck)
2007 Mazda CX-7 (the new commuter car)
2005 Mitsubishi Lancer (Rear Ended - TOTALED)
1998 VW Beetle (SOLD)
1988 Jeep Cherokee Limited - (SOLD)
mfalik is offline   Reply With Quote
Old 05-09-2007, 12:09 PM   #7
dand3053
Wouldnt be caught dead in one of those things!! I had a full size heavy duty Chevy pick up truck before the Jeep and a few cars in between but they were all AMERICAN! Once you go to a truck or SUV, you dont really want to go back to a car. just my opinion
Old 05-09-2007, 02:24 PM   #8
bobbert350
only if its mpi it wont make a difference on tbi the fuel has more room to atomize so it does make a difference
88 jeep wrangler, 4.2, auto---cragar soft 8's, d35 locker, bucket seats with 5 point harnesses, warn bumper w/ grill gaurd, winch plate, kc daylighters, light bar, herc the interrior, rebuilt tranny (yay) with tranny cooler, winch and msd ignition, 3.5 inch fabtech lift, currie boomerang shackles f/r, weber carb...[B]
[B]Why only go anywere fast when you can go anywhere[/B]
bobbert350 is offline   Reply With Quote
Glock Forum
