fuel pump won't work - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > fuel pump won't work
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light BaRuffstuff 10 year sale
Unread 11-14-2006, 06:16 AM   #1
jeep795
so after i put my gas tank in the back, i can't get the jeep to start anymore. it would crank and crank, and the fuel pump would turn on, but nothing would turn over. i got a new tank and sending unit put in, and now the pump won't turn on, i was assured the pump was working before, so i'm at a loss... i checked the fuse, and ohmed out the coil side of the relay. that part seemed good, plus i switched the relay and put it in place of the ignition one, and it still cranked so, it's fine. but any ideas on what to check before i go and spend 130 bucks on a pump?
jeep795 is offline   Reply With Quote Quick reply to this message
Unread 11-14-2006, 06:56 AM   #2
finwrangler
check that wiring is correct at the pump. i had problems connecting wires correctly, pumps looks the same, but polarity can be different.
stock 91YJ from Finland
I said NO to trackbars
finwrangler is offline   Reply With Quote Quick reply to this message
Unread 11-14-2006, 11:32 AM   #3
jeep795
the first thing i did was to check the harness. other then that i haven't really looked at too much else. i wire brushed a little bit of the rust that was on the ground but that's it. the wires are even the same colors as my old one.
Unread 11-14-2006, 12:27 PM   #4
hulken
did you prime the fuel pump?
hulken is offline   Reply With Quote Quick reply to this message
Unread 11-14-2006, 02:18 PM   #5
PhilipJ
This happened to me when I had to replace my pump. I oriented the new one the exact same way as the old one... positive on the left, nozzle high in the middle and negative on the right. It wasn't until I had to drop the tank again and yank it out that I realized, after prying back the bushing, that the polarities were swapped.
A quick way to check is to loosen the hose clamps on the tubing from the tank where they meet the hard lines that go to the fuel filter. Half a crank will tell you whether you're getting fuel or not.
PhilipJ is offline   Reply With Quote Quick reply to this message
Unread 11-14-2006, 08:07 PM   #6
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
i had to ground my fuel pump/sender unit to the body. apparently the ground had corroded somewhere, and was just easier to run a new ground. i ran a wire from one of the bolts on the sender unit to the body....just a suggestion
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
leftlanetruckin is offline   Reply With Quote Quick reply to this message
Unread 11-20-2006, 12:57 AM   #7
finwrangler
hey there should be a ground wire at the hand brake attachment, and if its not grounded, car wont start. so check your hand brake (e-brake), if there is loose o-head wire, connect it to hand brake bracket.
