Fuel Pump/ Sending Unit, help please! - JeepForum.com
post #1 of 5 Old 03-07-2012, 10:13 PM Thread Starter
Smurphy23
Basically a new jeeper! Bought a 1989 yj last spring and only now getting time to have a little one on one time with her So this is my problem, i bought the jeep off a family friend who had it in heated storage for 6 years! When he stored it he removed the tank, then drained the lines, so in time he mixed the tank up with others he had laying around and gave me two 20gal he had narrowed it down too. One has the pump and sending unit in the tank, the other just the sending unit. Which one would be for mine? Its a 1989 2.5, 5 speed! Any help would be great, thanks in advance!
Smurphy23 is offline
post #2 of 5 Old 03-07-2012, 11:16 PM
2wheelmatt
1997 XJ Cherokee
I'm not sure if this is the case with Jeeps, but with what I have seen of carbed engines the fuel pump is usually external to the tank. I also know that I have a 94 with FI and my pump in in the tank with the sending unit.
2wheelmatt is offline
post #3 of 5 Old 03-07-2012, 11:34 PM
dodger889
The one with the pump in the tank you have a fuel injected engine.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #4 of 5 Old 03-07-2012, 11:45 PM
hfa8592
X2. The 2.5 in YJs was always fuel injected, so pump and sending unit should be in the tank.
Scott
'93 YJ, 4" spring lift, 4.0 I6, NV4500, Atlas II, SYE, Currie/Ford 9" rear axle, ARBs front & rear, Kilby OBA, 33" Wrangler MTRs, custom cage, custom bumpers.
hfa8592 is offline
post #5 of 5 Old 03-08-2012, 04:46 AM Thread Starter
Smurphy23
Perfect thanks a lot guys!
Replace Fuel Pump or Fuel Pump/Sending Unit assembly? Muratus TJ Wrangler Technical Forum 10 02-09-2012 09:08 AM
What fuel sending unit?? 87 Wrangler 4.2 mechanical fuel pump 20 gallon tank Chris Aunchman YJ Wrangler Technical Forum 1 08-27-2010 03:54 PM
1998 TJ wrangler - fuel pump sending unit / fuel gauge drummerchukb1 TJ Wrangler Technical Forum 3 05-11-2009 04:42 PM
Fuel Sending Unit/Pump - 1 unit in an 89? saxsan YJ Wrangler Technical Forum 3 10-01-2007 11:48 AM
'95 Fuel pump/sending unit ? Tnuts YJ Wrangler Technical Forum 1 04-12-2002 11:53 AM
