Fuel pump sending unit - JeepForum.com
post #1 of 5 Old 08-16-2011, 11:10 AM Thread Starter
92renegade
I found a fuel leak on the metal lines that run into the fuel pump sending unit. Right at the top where they bend 90 degrees into the top of the tank .Is there a way to replace those? I see dorman makes some replacement lines, but I don't see how you would seal the lines after replacing them. Where would be the cheapest palce to purchase just the sending unit? I have the plastic 20 gallon tank.
92renegade is offline
post #2 of 5 Old 08-17-2011, 12:22 AM
yjluv
I ran into the same thing about 8 months ago. I wanted to somehow fix the problem with attaching new lines but couldn't figure out how to do it. I ended up buying a sending unit/ fuel pump at a local salvage yard for $75. I bought one first on e bay but it ended up being in worse shape than my original. Good luck!
yjluv is offline
post #3 of 5 Old 08-19-2011, 08:12 AM Thread Starter
92renegade
Well after no luck finiding a used sending unit or a resonable priced one,I decided to fix mine for a total of $11 and about an hour of my time. I will try to write up the details as much as possible to save fellow jeep owners money.
post #4 of 5 Old 08-19-2011, 08:20 AM
oldtime_ironman
Hey, another NY Jeeper! Yes, please do a write-up, it sounds like a good idea!
oldtime_ironman is offline
post #5 of 5 Old 08-19-2011, 09:17 AM
leadsled01
Local guy will rebuild/retube sending units. Radiator shops sometimes will work on sending units too.
leadsled01 is offline
Replace Fuel Pump or Fuel Pump/Sending Unit assembly? Muratus TJ Wrangler Technical Forum 10 02-09-2012 09:08 AM
Fuel pump sending unit? M. Lowes YJ Wrangler Technical Forum 2 06-07-2011 06:51 AM
What fuel sending unit?? 87 Wrangler 4.2 mechanical fuel pump 20 gallon tank Chris Aunchman YJ Wrangler Technical Forum 1 08-27-2010 03:54 PM
1998 TJ wrangler - fuel pump sending unit / fuel gauge drummerchukb1 TJ Wrangler Technical Forum 3 05-11-2009 04:42 PM
Fuel Sending Unit/Pump - 1 unit in an 89? saxsan YJ Wrangler Technical Forum 3 10-01-2007 11:48 AM
