#16 | ||
Not standard, optional.
I did the mod to my '91, and to the wife's '93 and both had the 10-1/2" long vent tube that limited fuel capacity to around 15 gallons. Now each hold 20+ gallons. Max ![]()
Click here to see all of my different albums on Photobucket. Choose any album to see all of my pics! Mean Max is setting up his Jeep shop! Picture history of my progress here. Quote:
There is no situation that cannot be improved with a small but well-placed explosive.
#17 |
I did not know that???
My '93 has a 20 gallon tank...so I just assumed all '93's did. I know my Yj is a "sport" or "s" version though, not necessarily a stock Jeep. |
#18 | ||
AFAIK, it was an option on all poly tank equipped '91-'95 YJ's. I would find it easy to believe that the "20 gallon tank option" was included in certain trim levels & special edition packaged models. Max ![]()
#19 |
yeah guys thanks for the help...I'm good except for getting the freaking pump back into positon inside the tank...lol!! it's like a puzzle how the hell am I supposed to get the pump to sit inside that freaking plastic rectangled piece and be flulsh to the tank?? LOL!! call me or something...860.759.4013 ASAP!
~ Love Rocks ~ |
#20 |
you have to get the screws started and sort of such the top of the tank back up into position. the rubber boot thing does need to be in the hole in the bottom of the tank though. Its supposed to be that tight to prevent the pump from banging around in there. Also while your in there check the white plastic box to see if its warped at all on the side the float for the fuel level gauge is, its pretty common for them to get misshapen after a while and then the float hangs up at 1/4 tank or so and you run out of gas until you know any better.
#21 | ||
![]() It is a puzzle! You just have to move it around (twisting & such) until you get it lined up just right. Also, make sure the rectangle shaped plastic baffle (the box) hasn't broken free. Sometimes they get loose & move around, if that's the case just remove it altogether. You may have to break it into pieces to get it out, if you end up removing it. It helps keep fuel near the pump while turning & at odd angles, but for everyday normal driving it's not as important. You'll also want to avoid getting very low on your fuel level if you do remove it. Max ![]()
#22 | |
#23 | ||
Max ![]()
#24 |
That plastic box...A baffle.
Yeah, mine was warped and stopped the sender unit from moving so the gas gauge didn't work. So I cut a slot in the baffle for the sender to move. Worked great. The only thing that needs to be inside this baffle is that screened intake. Here is a pic I just cut a hole, basically cutting the warp out. ![]() |
#25 | ||
Max ![]()
#26 |
okay...well after 3 days of waiting, several cuts and bruises and 7 hours of replacing the fuel pump...the freaking Jeep STILL wil not start..wtf??? It wants to turn over but won't...I have replaced the coil, the plugs and wires are two years old and yes, I did let it prime first! LOL! what the heck could it be??
~ Love Rocks ~ |
#27 |
Is it turning over but not starting or just not doing anything when you turn the key?
When you first turn on the key, can you hear the pump for a few seconds? Did you change the fuel filter? Silly question, put enough gas back in? Look at the simple things first.
1992 YJ Project, mainly stock, 2.5, true-track rear, true-track front, w Meyers plow |
#28 |
all that has been checked....and there is enough gas...and yes it is starting, but not turning over. It might be the CPS, that is what Mean Max thinks...so I will be checking that tomorrow.
~ Love Rocks ~ |
#29 |
okay! so I have replaced the fuel pump, the CPS AND then ignition pickup....and STILL no FREAKIN POWER!! I have determined that when the key is turned there IS POWER (my neighbor has a tester) but the minute the fuel pump kicks in, we lose power...it will not hold the connection!! I am going crazy....I can change parts but ELECTRICAL??? out of my league!! I need help! What we think is I am not getting power to the coil...I tried to follow the blue wire (we dtermined is not getting power) but I seriously have no clue where to folow it, how far or anything!
So if anyone has any schematics, or knows anything about what I am goingthrough please, oh please feel free to email me ASAP! aquarian5@msn.com Thanks so much in advance for any help you can offer!! Kim ~
~ Love Rocks ~ |
#30 |
Did you check the ground by the parking brake bracket ?
MIKE http://www.dav.org/ MJM Powder Coating Elizabethtown Ky. http://www.cityprofile.com/ |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
