#1 | |
Fuel Pump Replacement!
I need HELP! LOL! I need someone who is REALY great at being able to guide me through the replacement process via telelphone...lol!
I have the fuel pump and I sort of know thelocation, just not sure how to drain the tank, drop it and replace the pump...sooo if anyone either lives near Middlefield or is awesome at telephone instruction...hit me up!! 860.759.4013 Thanks so much!
~ Love Rocks ~ |
#2 |
aww 10 views and no response? LOL! what's up boys?
~ Love Rocks ~ |
#3 | |
Click here to see all of my different albums on Photobucket. Choose any album to see all of my pics! Mean Max is setting up his Jeep shop! Picture history of my progress here. Quote:
There is no situation that cannot be improved with a small but well-placed explosive.
#4 |
THANK YOU!! I knew I could count on you! I DID go to that site, but I didn't get that response...how did you find that post?
Actually it doesn't matter...thank you thank you!! Now for me to try and do it...lmfao this should be fun!!
~ Love Rocks ~ |
#5 | ||
Post up any questions you have along the way & we'll try to help out! Good luck! Max ![]()
#6 |
yeah I think so too..but honestly, the stuff about the gas relief valve, and the broomstick....I had no idea about that stuff...lol so once again THANKS SO MUCH!!
~ Love Rocks ~ |
#7 | |
You're welcome Kim!
Max ![]()
#8 |
Siphon gas, remove hoses to the filler neck, remove skid plate, drop the tank, remove fuel pump from tank. Reverse the order to put it back together.
1991 Jeep Wrangler 2.5L, 5 speed 2003 SVT Cobra Supercharged 32V 4.6L, 6 speed |
#9 |
Thanks Jeeeeeeeeeep lol I think I got all the "E's" in there... okay now I got get a hose to siphon...oh man fun fun!!
~ Love Rocks ~ |
#10 |
okay well, I think I got everything down but it's going to be too dark to work outside and a little afraid of using the lamp I have because it gives off way too much heat, sooo going to get up early and work on it. Thanks for all your help guys and I will keep you posted.
~ Love Rocks ~ |
#11 |
okay...well removing the skid plate...not soo freaking easy! LOL! After massive amounts of WD40, still can;t remove those freaking nuts...my hands are beat up already lol! It's gonna be a looooong day!!
~ Love Rocks ~ |
#12 | ||
What you need is a true penetrating oil. One of the most popular is PB Blaster, the Jeepin' wrench twister's best friend. ![]() Keep us posted on your progress! Max ![]()
#13 |
Just a small note:
Sometime in your Jeeps life... There was a recall on the gasket around the top hole in the gas tank. (the square hole) You should have a rubber gasket about 1/4 inch thick. This is the recalled piece. The thick one is the replacement. If you have a fairly thin gasket there, you're Jeep was never recalled. However after 17 years, if it wasn't recalled, not sure I would worry about it much at this point... This pic shows that gasket. The one in my pic/tank is the "good/thick" gasket. ![]() |
#14 | |
Oh! I almost forgot!
![]() Make sure you do the free 20 gallon tank mod while you're in there! Wrangler YJ Gas Tank Modification 15 to 20 Gallons YJ Gas Tank 15-to-20 Gallon Conversion Personally though, I don't reinstall a short piece of the vent tube back in, I just remove it & chuck it. Yours will be easy to remove though, instead of pulling the hose out the the vent nipple on the tank, just reach inside the tank through the large fuel pump/sending unit hole & pull the hose all the way through to the inside of the tank and remove it through the large hole. I feel so naughty, I said "nipple" on JF!...... ![]() Max ![]()
#15 |
Max...
The '93 comes with a 20 gallon gas tank already. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
