Fuel pump question, middle of 2.5 to 4.0 swap - JeepForum.com
post #1 of 12 Old 11-12-2013, 01:55 PM Thread Starter
aleh17
Hey guys! So I'm in the middle of a 2.5 to 4.0 swap, I got the 4.0 out of a rolled Cherokee 98 and I have a fuel pump question.
Problem is my YJ is a 1990, so I guess I have the small fuel tank right? but the fuel pumps I find for it are for the 4.2 or 2.5 for my tank size. So in order to run the 4.0 and get the correct pump will I have to swap the fuel tank?
Thanks in advance!
aleh17 is offline
post #2 of 12 Old 11-12-2013, 01:59 PM
SeanB95YJ
I believe so.... unless you can rig a newer (4.0) pump to your current sending unit
on the plus side - you'll soon have a 20 gal tank
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 12 Old 11-12-2013, 03:05 PM
Randonexplosion
Deplorable
Randonexplosion's Avatar
Is your tank metal or poly? I think that is the deciding factor.
Randonexplosion is offline
post #4 of 12 Old 11-12-2013, 06:48 PM
owenb95
1987 YJ Wrangler
You could always put in a rail pump and regulator. That's what I had to do with my 4.2 to 4.0 swap. I have been using a high flow inline racing pump and a regulator from Summit racing, been working great since I installed it.
1987 yj 4.2-4.0 swap AW4 & NP 242, 31inch BFG All Terrains, 2.5 in. rough country lift, Thrush header back exhaust, K&N intake, Subaru World Rally Racing Paint
owenb95 is offline
post #5 of 12 Old 11-13-2013, 06:07 AM Thread Starter
aleh17
Thanks for the replies, my tank is metal one.
thats a very interesting option, would you mind to elaborate? Do you use something like this? http://www.summitracing.com/parts/sum-g3136-2/overview/
aleh17 is offline
post #6 of 12 Old 11-13-2013, 06:16 AM
owenb95
1987 YJ Wrangler
Yes you would use something like that. You would need a regulator that goes up to 60 psi because the 4.0 runs at 49psi. You would need a gauge like this,
http://www.summitracing.com/parts/sum-800160/overview/
To dial in the regulator to the right pressure.
owenb95 is offline
post #7 of 12 Old 11-13-2013, 06:25 AM
owenb95
1987 YJ Wrangler
I used this regulator exactly,
http://www.summitracing.com/parts/pfs-10686/overview/
The only cons about it are the size of the threads are huge. After months of dealing with leaks because of all the reducer couplings i needed to step down to my hardened line i decided to just use barbed fittings on the regulator and pump and just run rubber fuel injection hose. It was simpler, cheaper, and no leaks!
owenb95 is offline
post #8 of 12 Old 11-13-2013, 06:57 AM
Que89YJ
The 2.5L tbi fuel pump should put out more than enough pressure to supply the OBD2 cherokee 4.0. So you dont need to buy a new pump just the regulator. If you happen to find a poly tank from a 91-95 YJ I would use it. The extra 5 gallons is nice!
Que89YJ is offline
post #9 of 12 Old 11-13-2013, 07:09 AM
SeanB95YJ
Hey Que... I thought the TBI systems run PSI somewhere in the teens to low 20s, where the MPFI (4.0) is more in the 30s-low 40s range?
or is the 2.5 TBI pump just regulated way down to accommodate the TBI requirements?
swap/build thread:
post #10 of 12 Old 11-13-2013, 07:15 AM
Que89YJ
It does but it is regulated down at the rail. The pump still cranks out at least 50 psi on both so no problem using the pump from a TBI setup. You just have to deal with the pressure like Owen said because the OBD2 has the regulator in the tank.
Que89YJ is offline
post #11 of 12 Old 11-14-2013, 01:02 PM Thread Starter
aleh17
Good stuff guys, thanks a lot for the info, I just ordered exactly what owenb95 told, I will be re-using my fuel pump since you guys are saying it works, but just for future reference, if I want to replace the pump can I used the ones made for the 20 gallon thanks or is it different?
aleh17 is offline
post #12 of 12 Old 11-14-2013, 01:23 PM
Que89YJ
Its different. i would still keep my eyes open for a poly tank.
Que89YJ is offline
