Fuel pump problem - Page 2 - JeepForum.com
post #16 of 18 Old 09-18-2013, 10:27 AM Thread Starter
jskinner9999
First of all THANKS everyone for the great advice on this problem. I disconnected the return gas line from the fuel bar, covered the hole on the fuel bar with my finger and engaged the fuel pump. 40 psi was on the fuel bar. I was able to crank the engine. Looks like NAPA sold me a bad fuel regulator. What are the odd on having a fuel regulator go out then NAPA selling you a bad one. Thanks again.
jskinner9999 is offline
post #17 of 18 Old 09-18-2013, 11:48 AM Thread Starter
jskinner9999
First of all THANKS everyone for the great advice on this problem. I disconnected the return gas line from the fuel bar, covered the hole on the fuel bar with my finger and engaged the fuel pump. 40 psi was on the fuel bar. I was able to crank the engine. Looks like NAPA sold me a bad fuel regulator. What are the odd on having a fuel regulator go out then NAPA selling you a bad one. I got a new regulator. Jeep is running!! ALL IS GOOD!! I could not have fix this without you guys. Thanks again.
post #18 of 18 Old 09-18-2013, 01:41 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
wow... Bad fuel regulator out of the box. I'm getting better at guessing.
Glad you got it fixed.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 33" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
fuel assembly , fuel pressure , fuel pump
