Fuel Pump !!! No Pressure at Fuel Rail!!! - JeepForum.com
post #1 of 3 Old 11-18-2002, 10:36 PM Thread Starter
turfman*
I need Help !
'92 4.0 Wrangler
Changed Fuel filter and fuel pump. Tried to start it and bleed off air at the injector fuel line. I had pressure than the fuel rail had no pressure...
Checked fuel filter direction flow arrow face to front looks ok. Dropped the tank checked hook up, and replace fuel pump with another new one.
Turn key on fuel pump will pump than goes off, still know pressure at the injector fuel rail.....
any areas I'm missing????
I don't think fuel line is blocked. fuel pump does not fill fuel line with fuel ???
turfman* is offline
post #2 of 3 Old 11-18-2002, 11:17 PM
lostboy
Fuel pump will shut off when it senses no demand. Tip I got was to turn key,wait for pump to shut off, bleed rail....repeat several times until fuel flows steadily...it may take several tries to bleed the fuel rail
89 yj w/ mopar mpi and 4.0 head.94 ax-15 tranny and t-case, more mods comin.
lostboy is offline
post #3 of 3 Old 11-18-2002, 11:26 PM
lostboy
Before I get beat up on here,let me clarify.
The fuel pump actually pulses.When fuel is not flowing to the injectors,there is back pressure in the line and the fuel pump will shut down. Same thing with air in the line...too much back pressure and the fuel pump shuts down until the pressure is released.
It's the job of the fuel pressure regulator and the fuel return line to keep the rail at a constant pressure under different demands.
lostboy is offline
how do I check the fuel pressure regulator on the rail (2.5) carcollector TJ Wrangler Technical Forum 5 01-08-2010 10:21 PM
High fuel pressure at the fuel rail ChiroSean YJ Wrangler Technical Forum 5 12-17-2008 02:02 PM
Fuel rail pressure frostylemon YJ Wrangler Technical Forum 2 06-14-2006 07:30 AM
Replaced fuel pump & no gas to fuel rail Part 2 BrianBC YJ Wrangler Technical Forum 0 08-24-2004 08:20 AM
Replaced fuel pump & no gas to fuel rail BrianBC YJ Wrangler Technical Forum 11 08-22-2004 11:41 PM
