fuel pump maybe??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > fuel pump maybe???
97-06 Jeep TJ 03-06 LJ 4" Rough Country Suspension liRancho Shocktober is here for fall 2015!!!!You Pick the Size and Style of Lift Kit. We will Find you
Unread 08-20-2015, 08:42 PM   #1
silleYJ
fuel pump maybe???
I just recently started having problems with my 88 YJ 2.5L TBI. It will not run after the tank gets down to 3/4 of a tank. It runs fine if I keep the tank full, but when the tank and gauge drops to 3/4 of a tank it starts to sputter and die like I am not getting fuel. I fill it back up to full and it will run fine.
I have pulled my sending unit because I figured there may be a hole in the line somewhere and it is sucking air. It checked out good. Now I am thinking it may just be the fuel pump.
I replaced the original pump with a bosch (OEM I think) back in 2012. Now I am thinking about replacing it with MTS if this is my problem.
Any Ideas or opinions on the switch to an aftermarket pump??? I know Mean Max is going to say go with the MTS.
1988 YJ Wrangler 2.5L for fun
2014 WK Grand Cherokee for dependability
silleYJ is offline   Reply With Quote Quick reply to this message
Unread 08-20-2015, 09:48 PM   #2
kgbeast
My was reading that until i cleaned contacts at the gauge (my is 4.2). But i assume you made sure that this is not the case.
kgbeast is offline   Reply With Quote Quick reply to this message
Unread 08-20-2015, 11:11 PM   #3
Barberern
1970 J-Series Truck
Man I am having the same problem with my. 350 dauntless
Barberern is offline   Reply With Quote Quick reply to this message
Unread 08-21-2015, 06:13 AM   #4
silleYJ
I pulled the fuel sending unit and there is definitely over 1/2 a tank. My gauge has always been pretty close to right for a YJ. Tank is 11 inches deep and it measures about 8 inches of fuel in it. I have a tank access panel so it doesn't take as long to do this since I don't have to drop the tank.
Unread 08-21-2015, 07:51 PM   #5
silleYJ
so I just ordered a new MTS fuel sending unit and pump combo from Amazsomething.com for $150. hope this works! I will post back up my results
