Fuel pump issues - JeepForum.com
post #1 of 7 Old 07-03-2013, 08:03 PM Thread Starter
rusty94yj
Fuel pump issues
Hey I'm new to the forum and new to jeeps. Just picked up a 94 wrangler that's been sitting for 3 years bc "the fuel pump went out". Turns out the fuel pump works fine. when I remove the fuel pump relay and use a jumper lead I can send power to the pump and it runs fine. All fuses are good, all relays are good. Does anyone know of any sensors in the circuit the fuel pump may be reliant on to work properly? Or has anyone run into this before? Thanks for any help. Ps the battery is brand new and when I turn the key the starter cranks just fine, but the fuel pump never primes or pumps when I turn the key to ON.
rusty94yj is offline
post #2 of 7 Old 07-03-2013, 10:46 PM
Strugoi
What was the jeep doing that made you think of the Fuel Pump?
Hey Rusty,
How was the jeep acting when you discovered that it was fuel pump relay?
Was it sputtering and backfiring? How did you test the fuel pump? Do you have pics? Sorry to be a pain, but I just posted a question on my jeep and I suspect that the pump may be related to my problem.
Strugoi is offline
post #3 of 7 Old 07-04-2013, 05:24 AM
kloppk
Rusty,
Do you get any dashboard idiot lights coming on when you turn the key to the RUN position?
If not then the PCM may be bad or not getting power.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #4 of 7 Old 07-04-2013, 11:07 AM
Strugoi
I do now that I changed out the oxygen sensor. I have yet to put a code reader on it because it usually resets once I turn off the jeep. I posted yesterday (7/3/13) about the 94 YJ that is backfiring and sputtering, the full details are in that post.
Strugoi is offline
post #5 of 7 Old 07-05-2013, 02:07 PM Thread Starter
rusty94yj
The jeep hasn't run since I picked it up so no symptoms to report. http://www.jeepforum.com/forum/f12/f...-help-1396299/
I followed directions in that thread to jumper the relay and test the pump
post #6 of 7 Old 07-05-2013, 02:10 PM Thread Starter
rusty94yj
Kloppk,
No idiot lights when the key is on, just break and seatbelt. Thanks for the tip on the PCM ill look into and I guess start doing voltage drops on the circuit? Ill let u know if I stumble into a solution.
post #7 of 7 Old 07-05-2013, 04:42 PM Thread Starter
rusty94yj
Update: I back probed the fuel pump side of fuel pump connector. Volts test with key on provided basically 0 V. I disconnected fuel pump from wire harness and did a continuity test on the plug coming from wire harness. With negative lead connected to the frame I use the positive lead to test the coupling and found continuity on 2 of 3 pins. Green w/ black wire has continuity, blue wire had continuity and black w red wire does not. Double rainbow size what does this all mean? If anything?
