Fuel pump gets loud after driving - JeepForum.com
post #1 of 5 Old 04-05-2010, 07:12 PM Thread Starter
JSchnob
I recently noticed my fuel pump seemed to be loud. So i changed the filter and it was normal again or so I though. This weekend I headed up to the mountans to scope out some new camping spots. On the way up I had the tunes on and didn't notice it start again. It sounds like the pump is constanly trying to prime itself. I headed for home as soon as I noticed, thinking the pump was dying but I made it. I came in, went on here to read up on those symptoms and found a few things to try. 1/2hr later headed out and the sound is gone. The Jeep ran the same while making the humming sound. The only thing I noticed was a bit more draw on the alternator when making the sound. I switched around the relays and they seemed to be working. If it's the pump then i'll change it but it's $220 for the pump here in Canada plus the time to have it installed. Doe anyone have any other idea's as to what would cause this. If it's broke then just stay broke so I know what to get fixed..?????
JSchnob is offline
post #2 of 5 Old 04-05-2010, 08:05 PM
Burnerman
Burnerman's Avatar
Mine is doing the same thing. I have a new pump on it's way. I just swapped in a 92 engine and trans and I used the 92 tank and pump. The Jeep sat for 2 yrs with little to no gas in the tank. It was quiet but after 100mi I too heard that loud buzz of the pump. Today I started it and it was quiet. I'm not chancing it. I ordered a rebuilt OEM pump from here...DirectAuto.com - 1992 Jeep Wrangler 4.0L VIN S Rebuilt Fuel Pump OEM # 4637193
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #3 of 5 Old 04-05-2010, 08:14 PM
idaholtby
When my fuel pump went bad it emitted a loud whine from the tank. The Jeep still ran fine, but the noise was obviously coming from the fuel tank. It was replaced, and since then, all was quiet. If the whine is coming from the rear of the jeep when idle, it can only be the fuel pump telling you it is about to give up the ghost.
idaholtby is offline
post #4 of 5 Old 04-05-2010, 08:38 PM
H3RTCH
Live Free or Die.
H3RTCH's Avatar
Mine whined more constantly I believe. After 197k miles, I can justify the longevity of the stock one (as far as I know). Also, when I replaced mine, the jeep seemed to run a bit better. More smoothly. That may just be the placebo effect though
Good luck my friend
2004 Jeep WJ Grand Cherokee Overland - My DD
1988 Jeep MJ Comanche 4.0L - Dad's
1999 Jeep WJ Grand Cherokee Limited 4.0L - Mom's
H3RTCH is offline
post #5 of 5 Old 04-05-2010, 08:58 PM
idaholtby
Good luck my friend
Ahh yes, the piece and quiet of a new fuel pump. The serenity it provides when you are 120 miles off of the beaten path.
Replace Fuel Pump or Fuel Pump/Sending Unit assembly? Muratus TJ Wrangler Technical Forum 10 02-09-2012 10:08 AM
2001 TJ Stall while driving/ Fuel pump relay keeps blowing CPClink5955 TJ Wrangler Technical Forum 0 02-10-2010 08:20 PM
Fuel pump loud. xtremexp TJ Wrangler Technical Forum 4 03-07-2007 05:07 PM
Loud fuel pump KOTA YJ Wrangler Technical Forum 11 11-19-2006 10:19 PM
Loud sound when driving FarrellX YJ Wrangler Technical Forum 33 09-24-2006 02:08 AM
