Fuel pump/fuel pressure testing - JeepForum.com
post #1 of 3 Old 03-23-2011, 07:02 PM Thread Starter
kbfunTH
How do I know if the fuel pump is bad on my 89 2.5L? Is it easy to test fuel pressure on the engine? Are there any sensors to check first before dropping the tank and pulling the pump?
Acts 4:12
kbfunTH is offline
post #2 of 3 Old 03-23-2011, 07:39 PM
moonshinefuel
There are fuel pressure testers that you can connect right onto the fuel line itself. It is pretty easy to do yes. Some might mention to check all of your fuses/relays, I believe there is one for the fuel pump on the 89.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #3 of 3 Old 03-24-2011, 01:07 PM
Que89YJ
There is a fuel pump relay, You should run a fuel presssure test to make sure. You can rent the unit at most auto parts stores with a deposit that you get back when returned. If you need help do a test post back and we can tell you how its done. Pretty easy to do.
Que89YJ is offline
How to test fuel pump/fuel pressure on '05 4.0L Zen TJ Wrangler Technical Forum 18 05-12-2010 09:34 AM
testing the fuel pump vitapimp TJ Wrangler Technical Forum 4 03-23-2010 02:17 PM
Testing fuel pump crankyman YJ Wrangler Technical Forum 3 05-23-2006 02:51 PM
Fuel Pressure and Pump Q's NIUPonyBoy YJ Wrangler Technical Forum 10 07-25-2004 10:18 PM
Fuel Pump !!! No Pressure at Fuel Rail!!! turfman* YJ Wrangler Technical Forum 2 11-18-2002 11:26 PM
