Fuel pump died - JeepForum.com
post #1 of 14 Old 11-03-2011, 09:35 AM Thread Starter
94chb
Fuel pump died
just bought a used fuel pump assembly to use on my swap and after getting it all done i took it for a ride and when i turned it off it wont run anymore. the pump just clunks everytime you turn the key on but wont hummm and pump fuel. im gonna drop the tank later today and see whats going on.
has anyone bought a new fuel pump from autozone?
94chb is offline
post #2 of 14 Old 11-03-2011, 09:38 AM
Ripper3494
We bought one from Car Quest last year and it worked fine. It was not OEM. Make sure to check the electronics and relay before you bother dropping the tank. That, ultimately, was our problem. Fuel pump was fine.
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #3 of 14 Old 11-03-2011, 09:44 AM Thread Starter
94chb
i unhooked the fuel line and nothing comes out. the pump just makes a clunk noise and wont hummm
94chb is offline
post #4 of 14 Old 11-03-2011, 09:54 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
as you know that pump should never clunk. I have swapped out 4 and never had one clunking.
I recommend a Bosch pump
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #5 of 14 Old 11-03-2011, 10:00 AM
Que89YJ
X2 with Poke....get the Bosch
Que89YJ is offline
post #6 of 14 Old 11-03-2011, 10:33 AM
Ripper3494
Actually, we got it from Napa, and come to think of it, it was a Bosch. Still have the box.
build thread:
RC vs BDS
post #7 of 14 Old 11-03-2011, 10:43 AM
Andywear
I got my pump from Auto Zone they price match other stores.
and also dont forget if needed, to buy the filter that goes on to the pump.
For my '91 the pump was round $135
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #8 of 14 Old 11-03-2011, 12:13 PM Thread Starter
94chb
i just paid $125 for the whole pump and assembly from a member here and bought a new screen to finish my swap then it died so i wont have to buy another screen. just the pump
94chb is offline
post #9 of 14 Old 11-03-2011, 06:04 PM
Mark05059
unless it swallowed the screen
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #10 of 14 Old 11-03-2011, 09:37 PM Thread Starter
94chb
i dont think it could. this is the style i have
94chb is offline
post #11 of 14 Old 11-04-2011, 03:25 AM
Mark05059
all that screen stuff can/does break up and could wind up in your fuel pump along with any plastic stuff that came off the internals of the pump which is now in your filter or will be after the fuel brings it there... you do what you want but if it were me I would be changing the filter again so I dont have to change the injectors later if the stuff gets by it or have a plugged up filter down the road.
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #12 of 14 Old 11-04-2011, 12:17 PM Thread Starter
94chb
the screen is only 40 mins old lol, i just bought it, i doubt thats the problem . im gonna drop my tank today and see whats going on.
94chb is offline
post #13 of 14 Old 11-04-2011, 03:17 PM
Mazdarx
I just had a similar problem. My fuel pump had power, and it would come on and make a clunk sound once. It did this every time I turned the key, also when I ran power directly to it. I pulled it out and that filter/strainer thing was gone. I'm pretty sure that it came off or fell apart and jammed up the fuel pump.
-My business, being self-employed rocks.
91 Yj Renegade, lifted, built 4.0L, 33's etc
Mazdarx is offline
post #14 of 14 Old 11-04-2011, 05:39 PM Thread Starter
94chb
i dropped tank today and pull pump and tested it, and its no good, so ill need a new pump
94chb is offline
Replace Fuel Pump or Fuel Pump/Sending Unit assembly? Muratus TJ Wrangler Technical Forum 10 02-09-2012 09:08 AM
98 TJ died while driving and now it barely starts/runs.. Fuel pump? deerkilla4500 TJ Wrangler Technical Forum 5 10-17-2010 01:10 AM
wipers just died today but the pump works? vicker YJ Wrangler Technical Forum 1 06-14-2010 06:47 PM
jeep died. Fuel pump?? GRN_BEAST95 YJ Wrangler Technical Forum 27 10-26-2009 08:02 PM
Running Great, died suddenly. Fuel pump? Treeslam YJ Wrangler Technical Forum 8 03-08-2009 10:22 PM
