Fuel pump?? - JeepForum.com
post #1 of 2 Old 10-23-2001, 07:45 PM Thread Starter
Nine5YJ
Fuel pump??
Hey-
I have a 95 YJ 2.5L with very fed mods, and i am at about 32,600 miles. I am overdue for the 30K tune which calls for spark plugs etc.. When I accelerate, it jerks and the throttle response is horrible. Could i have a blocked fuel line? Could my plugs not be firing? Any input greatly appreciate!
Thanks Alot!
-Tom
95 YJ
95 YJ, 31 x 12.5 ProComp ATs / AR767 wheels, stock 4.10s, 2 1/2" Rough Country Suspension Lift, and huge rusty basketball sized drain holes.
Nine5YJ is offline
post #2 of 2 Old 10-24-2001, 02:24 PM
glm 87 wrangler
A tune up may be your solution.Check or replace your spark plugs,distrib.cap,rotor botton,if that model has distrib.cap and rotor.Replace fuel filter air filter,and check or have some check ignition timing.
change wires if they look or seem old.Check crank case breather filter and or pcv valve if your model carries one.Good luck.keep me posted.Oh rember its always good to change your radiator fluid every 2 years to keep the radiator in top health..also keeps the heater core in top health also.50/50 solution in radiator an 100% coolant in the coolant jug.
check or replace belts and hoses add needed..
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
Replace Fuel Pump or Fuel Pump/Sending Unit assembly? Muratus TJ Wrangler Technical Forum 10 02-09-2012 09:08 AM
1998 TJ wrangler - fuel pump sending unit / fuel gauge drummerchukb1 TJ Wrangler Technical Forum 3 05-11-2009 04:42 PM
inline fuel pump or new tank with pump in it? cubbybear YJ Wrangler Technical Forum 2 12-25-2008 05:13 PM
Fuel pump assembly vs. fuel pump? eclipse27 TJ Wrangler Technical Forum 11 11-11-2008 09:18 AM
Electric Fuel Pump Issue, NOT pump 1995yj1978cj YJ Wrangler Technical Forum 4 05-28-2005 12:12 PM
